Max28 FEL quick attach
/ Max28 FEL quick attach #1
edlegault
We are thinking about a Max28, a lot because of the front loader lift capacity. I read conflicting info on the availability of a quick attach for the front end loader. Mahindra people... is there or is there not a quick attach system, either Mahindra or an off the shelf system from a third party, for the Max28 FEL?
thx.
/ Max28 FEL quick attach #2
I am sure there is not an OEM QA... you might be able to find one after market though... I would be wary doing this due to warranty issues.
/ Max28 FEL quick attach #3
You never know what a manufacturer is going to claim, but it's hard for me to imagine how a QA would void a warranty. It should just pin on in place of the bucket, right? How is it different from any other implement that one might pin onto one's loader arms? Might as well claim you're going to void a warranty by changing out your bucket for pallet forks.
You might look into whether the Titan QA conversion kit shown in this thread (http://www.tractorbynet.com/forums/attachments/270316-quick-attach-conversion-kit-need.html) will work for you. The way it works is, Titan supplies the QA adapter, but it doesn't have the pin-on "ears". You cut the ears off your bucket and weld them to the adapter, thereby guaranteeing that the adapter will properly fit the loader. Then you weld a QA plate onto the bucket.
/ Max28 FEL quick attach #4
It falls under the category of "manufacturer approved attachments"...
/ Max28 FEL quick attach #5
We offer the WR Long Quick Attach Adapters that will convert the loader to universal SS quick attach. It will be custom made to pin onto your loader. The mahindra max loader is not on file so you'd need to fill out a blank drawing with some measurements in order for them to build one.
/ Max28 FEL quick attach #6
I'm really just stunned that this might even be an issue. The whole point of the loader is that you can change out attachments. I suppose if you put a huge bucket on the tractor that caused you to overload the thing and damage the loader, you might have a point, but it's always the case that if you damage your device through stupidity or carelessness, the manufacturer will try to refuse the warranty. There's no way I can imagine that a manufacturer would get a blanket veto on what attachments I can and can't put on my FEL. I mean, does that apply to the three-point? Can I use any Cat-1 three-point implement on my tractor, or will I void my warranty if I use an implement that is not OEM?
/ Max28 FEL quick attach #7
The key is that there is no QA designed for you loader. It's done that way on purpose. Your three point is designed to attach to all types of things built to that standard. I am not saying you WILL have an issue, and the chances are good (especially with Mahindra) that you won't... but it's something you have to be aware of.
/ Max28 FEL quick attach #8
One of the Tag lines for Mahindra Max tractors is that they are "Real Tractors, not lawn mowers".
If putting a QA on a Max is a "Real Issue" for warranty, and you really want one, maybe you should consider going with a more refined, "Lawn Mower" like Kubota that is not afraid of a QA on their equipment.
YIKES, watch out, here comes the thunder.
/ Max28 FEL quick attach #9
Rut-roh
So then, how does the Mahindra pallet fork fel attachment hook to the FEL? Looks like it might be a QA. Or do the pins have to be punched out and replaced each time a swap is made? Does anybody out there actually use this? How quick is it to change out?
What's happening is we are building a house and barn/hobby studio this summer. There will be a few things delivered to us separate from the contractors that we will need a tractor with FEL pallet forks (or a separate forklift) for up to about 1250 pounds to unload from the delivery truck and maneuver around the homesite (manufactured fireplace at 400#, propane gas ceramics kiln at 1250#, miscellaneous hobby stuff at 500-1000#, etc.). The Max28 seems to fit our needs for both a very small farm of just a few acres and the construction phase.
/ Max28 FEL quick attach #11
You must remove the pins each time you change the attachments. The nice thing about the forks, they are also compatible with your 3-point hitch. By the way, these are manufactured by Kodiak. https://www.forddistributing.com/products/kodiak-pallet-fork-pallet-forks
/ Max28 FEL quick attach #12
You may want to look into how much weight you can lift with the forks. I have to assume the loader lifts less the further out from the FEL arms you get.
/ Max28 FEL quick attach #13
This is true. Is there an OE set of forks available for the ML205? I know there is not for the ML202. Based off of the earlier post about the things needed to unload (kiln) I doubt the Max28 is big enough to do that with forks.
/ Max28 FEL quick attach #14
I don't mean to be disrespectful, but unless you can come up with an example where a manufacturer actually tried to pull this, I think you're just fear-mongering. Assuming that you don't physically damage the loader, or overload it, or something like that, I don't see how it matters whether I punch the pins, take the bucket off, and put on a pallet forks, or a trailer mover, or a QA plate. Whether there is a QA plate between the bucket and the loader pins can't, in any sane world, be a deal-breaker on your warranty. There absolutely is a QA designed for your loader: EA will happily fabricate one from you, for example.
/ Max28 FEL quick attach #15
Now I am fear mongering.... sheesh... Clearly you think I know nothing about the business. I suggest you go search through my posts. At any rate you are right... as long as you don't tear anything up there it makes NO difference where you put the pins... that seems obvious, but you are right...
But... if you put and aftermarket QA and pallet fork set on there and bust your front axle or crack a bell housing... you will be on your own.
/ Max28 FEL quick attach #16
Not at all. I'm just trying to figure out whether you're talking from experience or conjecture, which is why I've asked you twice whether you know of an example of a manufacturer refusing warranty due simply to the use of a non-OEM FEL attachment. If you know of one, I'd love to know more about it.
At any rate you are right... as long as you don't tear anything up there it makes NO difference where you put the pins... that seems obvious, but you are right... But... if you put and aftermarket QA and pallet fork set on there and bust your front axle or crack a bell housing... you will be on your own.
Yes, but--and this has been my point all along--that's going to be true whether you've got a QA or not. I wonder if your point is not that the QA itself will void the warranty, but that the SSQA will allow you to pick up implements that are generally too large for the loader, and so will encourage you to overload it and damage it. If that's your point, then we're 100% in agreement. The operator must be responsible for knowing their machine's capabilities and not exceeding them.
/ Max28 FEL quick attach #17
OK... so I think in principal we agree...
And yes I know for 100% from experience that warranty can be denied for things like that. I happened to have just spent the morning processing loader warranty claims... ;)
The major sticking point is that the smaller the unit... the easier it is to add something to it that will tear it up like you were alluding to...
and in response to another post about Kubota... I have yet to find an OE QA offered for a similarly sized machine...
/ Max28 FEL quick attach #18
joshuabardwell, just in case you didn't realize it, rback33 is THE MAN at KMW loaders. KMW is who builds Mahindra's loaders. I am pretty sure that you cannot find ANYONE that will know more about all situations as far Mahindra loaders are concerned.
It's always fun to listen to or read what people have to say about things (good & bad) when they are conversing with someone in the know, but don't know to whom they are actually conversing with. ;)
/ Max28 FEL quick attach #19
I just looked and Kubota does not offer any QA for the B2920 and I didn't bother looking at any BXs.
/ Max28 FEL quick attach #20
What? How dare you suggest there might have been something that I didn't know!
:newhere: :rolleyes:
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2011 MAGNUM TRAILER LIGHT PLANT (A67714)
2011 MAGNUM...
Chariot Scrub 20 Electric Floor Scrubber (A64194)
Chariot Scrub 20...
