Max26XL ETR solennoid fuse multiple failures
   / Max26XL ETR solennoid fuse multiple failures #1
vietvetharry
Upstate SC
Mahindra Max26XL Shuttle, Montana C4864
I noticed a number of threads discussing the ETR fuse blowing causing the starter not to start. Has anyone found why that was happening? Did it have anything to do with the seat safety wiring shorting? Has anyone disabled the seat safety wiring?
   / Max26XL ETR solennoid fuse multiple failures #2
yes most probably the seat safety switch... ETR solenoid fuse will blow
   / Max26XL ETR solennoid fuse multiple failures #3
I've run into this issue several times. Always found improper routing of the seat switch pigtail causing the wire to get pinched. You may have to get under seat deck and cut the ties on the main harness to give you enough slack on the pigtail for good routing. :thumbsup:
   / Max26XL ETR solennoid fuse multiple failures #4
^:thumbsup:
1999 Toyota Camry XLE Sedan (A50324)
1999 Toyota Camry...
2015 F-550 Bucket Truck. (A52748)
2015 F-550 Bucket...
2012 BMW 328i Sedan (A50324)
2012 BMW 328i...
2011 Liebherr L586 (A52748)
2011 Liebherr L586...
2019 Dodge Challenger Passenger Car (A51694)
2019 Dodge...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
