Max26XL ETR solennoid fuse multiple failures
   / Max26XL ETR solennoid fuse multiple failures #1
vietvetharry
Upstate SC
Mahindra Max26XL Shuttle, Montana C4864
I noticed a number of threads discussing the ETR fuse blowing causing the starter not to start. Has anyone found why that was happening? Did it have anything to do with the seat safety wiring shorting? Has anyone disabled the seat safety wiring?
   / Max26XL ETR solennoid fuse multiple failures #2
yes most probably the seat safety switch... ETR solenoid fuse will blow
   / Max26XL ETR solennoid fuse multiple failures #3
I've run into this issue several times. Always found improper routing of the seat switch pigtail causing the wire to get pinched. You may have to get under seat deck and cut the ties on the main harness to give you enough slack on the pigtail for good routing. :thumbsup:
   / Max26XL ETR solennoid fuse multiple failures #4
^:thumbsup:
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
2017 Chevrolet Malibu Sedan (A50324)
2017 Chevrolet...
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2006 GAYLEAN  130BBL (A52472)
2006 GAYLEAN...
2015 Ford F-550 Auto Crane 4004EH 4,000LB Crane Service Truck (A51692)
2015 Ford F-550...
