Max Pics
/ Max Pics #2
It was difficult to tell by looking at their "Max" website but with people standing next to them, they don't look quite as large as I thought they might have been. To me, they look more like a riding lawnmower or an ATV with a FEL.
/ Max Pics
They look to me exactly like the old 16 series! I guess I just expected something more given all the hype! The Mitsu tractors are awesome and I'm not saying I would change anything, but then again I wouldn't promise my customer something that's going to "change" the industry and not change them either. Hopefully the specs show the "change" and I'm just missing something!
/ Max Pics #4
Boy i don't like the way those hydraulic lines run outside the loader frame, easy to catch on things looks like poor design......
/ Max Pics #5
I agree about those hydro lines.
/ Max Pics #6
Mahindra just wanted to jump into the SCUT market along with Kioti. So far, as looks go I like the Kioti SCUT a little better.:confused3:
/ Max Pics #7
I have not seen the Kioti Subs, but at the Mahindra National Dealer Meeting, I saw the MAX series set along the side of the Kubota BX, the JD Sub, and the Massey GC. The MAX is a lot of Machine setting beside them. No doubt it is similarly sized but a much more rugged machine.
/ Max Pics #8
What would be the going show price?
/ Max Pics #9
In which areas specifically is the new MAX more rugged than the competitors referenced above?
......EDIT.........
I just took the time to go to the Mahindra website. This is probably what stood out - Full frame tractor, cast iron center section.
/ Max Pics #10
loader capacity is what stands out for me. At 1400+ lbs, that's a lot of lift for a little tractor. Wonder how it does staying on the ground. I'd think definitely loaded tires and an implement.
/ Max Pics #11
Looks a bit like the setup guy just routed them on the outside, instead of the inside. Does anyone see a reason why they were hung on the outside?
/ Max Pics #12
The hoses are supposed to be routed inside. They just need to be uncoupled at the QCs and routed inside and recoupled.
/ Max Pics #13
......EDIT.........
That definately is a big plus, no plastic fan in the center to get broken, the drawbar is a drawbar just like the big tractors and not just a flap with a hole in it hanging off the steel frame like the others. A little bigger tires, the 3PH is standard and the 3PH components much heavier than the others. The 3PH is a full CAT 1 and has more lift capacity, and the loader has 900 lbs lift capacity,to full height. You should really see them side by side.
/ Max Pics
/ Max Pics #15
Thanks for the pics! That would make one **** of a garden tractor! Reminds me of the old garden tractors from the 60's and 70' but better!
2" X 2" DIAMOND BAR W/ SHANKS (A63291)
2" X 2" DIAMOND...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
Caterpillar D7H Series 1 and 2 Dozer Service Manuals (A63117)
Caterpillar D7H...
(4) METAL STANDS (A63291)
(4) METAL STANDS...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
2015 Nissan Altima SV Sedan (A61574)
2015 Nissan Altima...
