Max. incline/decline for JD1070??
   / Max. incline/decline for JD1070?? #11
From the sounds of it, DON"T run on the sidehill. Just back down to the logs and go straight back up.
If your tractor runs out of power or traction, then you will know to quit that approach.
Better to let the wood rot than risk your hide, especially if you are feeling a need to ask about it.
Explain better how you plan to move the logs? Hooking to the 3 ph ?
Can you comfortably drive your tractor down to these logs, turn around, and drive back up the hill with no wood at all?
If so, that is a start. If not, drop the idea of going down there with your tractor.
Consider a long cable or chains to stay above and drag the logs up the hill. Be very aware that you need to pull straight away, and not at an angle to the pull.
Don't try to get them in the bucket unless you are very confident in what you can and cannot get away with.
Wish you good luck and safe travel.
I agree with this good advice ^^^^^^ particularly the use of cables or chains to pull them up.
26ft x 42ft Double Garage All Metal Building (New/Unused) (A59225)
26ft x 42ft Double...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
Meyer 8.5' Snow Plow (A55272)
Meyer 8.5' Snow...
2019 WABASH DVLSHPC 53FT DRY VAN TRAILER (A59575)
2019 WABASH...
2018 Ram ProMaster 2500 Passenger Van (A56858)
2018 Ram ProMaster...
gps trailers (A56859)
