Max 28 turning off at high rpm's
   / Max 28 turning off at high rpm's #1
jsn329
Mahindra max 28xl
My tractor runs fine if the RPM's are not maxed out, Once I open the throttle all the way after 10-20 mins the tractor shuts off. It will start up normally after that, but will shut off again if I open the throttle all the way. It sounds as if the key is turned off. Any ideas? I was not sure if the fluid solenoid would cause this. I know I have heard a lot of people with a mahindra having fuel solenoid problems.
Thank you
   / Max 28 turning off at high rpm's #2
I believe you're referring to the fuel shut off solenoid...
Otherwise you'll need some MAX knowledgeable members to weigh in on the solution.
   / Max 28 turning off at high rpm's #3
Thank you
Is your fuel screen still in the tank filler neck ??? I see them get pushed down into the fuel tank with long funnels. The screen will block the fuel pick up. :confused3:
It is still in place thank you
   / Max 28 turning off at high rpm's #5
Try leaving fuel cap a little loose to let air in.
LEEBOY PF1510B ASPHAULT PAVER (A51406)
LEEBOY PF1510B...
2015 Crane Carrier Co. Low Entry T/A New Way Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
Heavy Duty Hydraulic 84" Broom  (A52384)
Heavy Duty...
JOHN DEERE WHEEL LOADER 71" FORKS (A51246)
JOHN DEERE WHEEL...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
