Max 28 Box Scrape
/ Max 28 Box Scrape #3
I have a heavy 6' Landpride unit that i have not tried. I suspect it will struggle, but it will be used mostly for grading. 5' is just right.
/ Max 28 Box Scrape #4
I have a 5 foot from TSC. Originally I bought a 5 foot from Mahindra (Kodiak), but was less than impressed with the quality and sold it.
/ Max 28 Box Scrape #5
54" is ideal but not too many guys stock that size, most guys go with a 60" box. If you have tire spin with the 60", you might load your rear tires.
/ Max 28 Box Scrape #6
How do you like the 5 foot from TSC?
/ Max 28 Box Scrape #7
Buy the heaviest 60" unit you can find, there is no substitute for weight! The max will pick it up no problem, if you spin the tires take 2 small bites instead of one big one.
/ Max 28 Box Scrape #8
I bought a 72" Landpride when I got my L39. Never ran it with the L39, as I used it only with my neighbors L3400HST with loaded tires. The 72" Box would stop that tractor in tough going. I hope the Max 28 can work a 6' scraper, as it has nearly as much power and weight if ballasted as a L3400. The box will be used for just spreading and grading as I have my excavator with a 92" blade and the L39 bucket for heavier pushing.
The Max has really good lift specs on the 3 point. I'll put it to the test re-doing our 1400' driveway & the logging road this year.
/ Max 28 Box Scrape #9
mike69440, I think that you will be much better off staying with a 60" unit. I know that a 6 footer sounds good, but you need to look at things realistically and I sure don't see a 6 foot box blade as being a good match for your 28XL.
Just my :2cents:
/ Max 28 Box Scrape #10
A 72" will be too big if you use the rippers or fill the box full with gravel. You will end up lacking traction I think. If you are just grading and not carrying a full box nor using the scarifiers much, it will work. I've used a 72" orchard float behind a Max28 before and it worked great.
/ Max 28 Box Scrape #11
I use mine with 4x4 engaged and have caught a root and was stopped instantly. Tractor was still trying to go, but lost traction. I think that loading the rear tires may be something I need to consider.
/ Max 28 Box Scrape #12
Many dealers will not sell you a tractor with a loader unless the rear tires are filled. Fill them and you will be amazed at the difference.
/ Max 28 Box Scrape #13
Just my :2cents:
I've owned the Landpride since 2005, I won't be ripping, just grading. i figure It will work as long as I don't fully load up the box. I als have a 7' York rake that my B7200 realy struggles with if I try to move a lot of dirt.
/ Max 28 Box Scrape #14
Id be running a 4ft box on that tractor if your really wanting to load it up with dirt
/ Max 28 Box Scrape #15
You ought to be fine. You obviously have a lot of operator experience. A careful operator can often run larger implements than we would suggest to the average guy. We try to keep people out of trouble.
/ Max 28 Box Scrape #16
I am going to try my 6' on my 26xl. Like you I won't use the rippers or fill the box. I will just use it to grade. If I need to use the rippers I'll put it on my big tractor.
UNUSED KIVEL 48" PALLET FORKS (A62130)
UNUSED KIVEL 48"...
2015 Nissan Quest Van (A61569)
2015 Nissan Quest...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
UNUSED CFG INDUSTRIAL H15R MINI EXCAVATOR (A62130)
UNUSED CFG...
2016 Land Rover SUV (A61569)
2016 Land Rover...
