MAX 22 4 years in
/ MAX 22 4 years in
The cover is a rattling sound, I have had to reposition the cover a couple of times, but the rubbing sound is clearly not the same sound, it is metal on metal rubbing unlike the shaft cover. I just got a parts breakdown from the manual, no zerk. Looks like I'll have to pull the pin and grease it up good and check the bushings.
/ MAX 22 4 years in
I found the damned zerk. I can't believe I missed it. It is dead center very high on the axle assembly. I am in a wheelchair so I couldn't get my head down low enough to see it, but when I got on the floor I found it and greased the heck out of it. It still makes a creaking sound from time to time, but it is substantially better.
/ MAX 22 4 years in #23
My old Ferguson manual specifically said not to grease the pivot pin. It said the grease would hold dirt and wear the assembly quickly. Sure made it squeek a lot.
/ MAX 22 4 years in
That makes sense, but it is designed to grease, and I have to tell you, the sounds before I greased were horrible. It is so much better now than before. I hope it isn't a design flaw having a Zerk.
GODWIN 6 HEAD PUMP (A65643)
GODWIN 6 HEAD PUMP...
2011 PETERBILT 386 (A67714)
2011 PETERBILT 386...
ROOM WITH MISC ITEMS (A67714)
ROOM WITH MISC...
AG Tires - 11.00-16SL (A68134)
AG Tires -...
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
