Material for hydraulic hard lines, Copper-Nickel or only steel?
   / Material for hydraulic hard lines, Copper-Nickel or only steel?
I would probably use Stainless lines and look for something with a 3,000 psi working. I would encourage you to go with 3/8" tubing as it will be close to 1/4" hoses in size. Tubing is measured by the OD and hose is measured by the ID. 1/4" tubing is extremely small and will be very very slow, the valve will basically be on or off with no feathering ability. A Ridgid 375 is a commonly used hand flaring tool however for 1/4" or 3/8" tubing I would suspect most flaring tools would work. For fittings Parker TX-S sleeves and BTX-S nuts would be the most economical choice.
Zoro has some reasonable tubing prices.
Strong & Resilient Stainless Steel Tubing | Zoro.com
Fittings for 3/8"
This is what is used on industrial equipment all the time and is a proven and durable approach.
I'll take a look. There is a 5/16 listed that has an ID of 0.272 which might be good enough. I would have to buy a flaring tool as I only have 45 degree tools.
It's for a top and tilt, with rather small cylinders. I've heard of people needing to put in flow restrictors to prevent slamming.
What are you using to bend the lines? Whenever I have had to bend small diameter stainless, brass, or copper tubing I used a tubing bender and had no trouble with kinking or distorting the round shape of the tube.
Eric
Have a couple styles of hand held tubing benders that more or less work OK.
More I look into this, may just go with flexible hoses. By the time I get the materials and a decent flaring tool, I'll be even older and poorer than now.
   / Material for hydraulic hard lines, Copper-Nickel or only steel? #13
Probably a good choice, hardlines for a one-time project rarely makes sense.
One of my concerns is the "bend radius" as the hoses will be under a foot long. Dawns on me I should get one made up locally and see how it looks, then go from there. I'll only be out about $30 if it does not work out.
   / Material for hydraulic hard lines, Copper-Nickel or only steel? #15
A 3/8" hose can bend pretty tightly.
   / Material for hydraulic hard lines, Copper-Nickel or only steel? #16
For bending tubing, especially when the wall thickness is pretty thin, a good fitting tubing bender will is almost a must. I think you're correct in looking into flexible hoses.
Eric
   / Material for hydraulic hard lines, Copper-Nickel or only steel? #17
Proper rated tubing and compression fittings!
Compression fittings for a 2100 PSI system? I was having a hard time convincing myself to use them on the tank return line, which I have have to resort to.
I tried removing the JIC male adapter threaded into the tank return on the hydrostatic, to figure out a replacement, so I could insert a T in that space, but managed about three turns before it got very hard to turn. Discretion VS VS Valor convinced me to thread it back in and go a different route. Guessing it is one of those tapered pipe threads and is well and truly distorted.
   / Material for hydraulic hard lines, Copper-Nickel or only steel? #19
I'm assuming he used that as a general term, and what he really means is "swagelock" style fittings, they are made for high pressure use.
   / Material for hydraulic hard lines, Copper-Nickel or only steel? #20
Joea99, if you were closer I could bend and flare steel lines while you wait, I have .250” to 1.500”.
Some types of stainless tubing doesn’t like to bend or flare, you would need to specify annealed tubing.
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
2016 HAMM HD+ 120I SMOOTH DOUBLE DRUM ROLLER (A51246)
2016 HAMM HD+ 120I...
UNUSED JCT 60" HD HYD CONCRETE MIXER (A51248)
UNUSED JCT 60" HD...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
23222 (A50323)
23222 (A50323)
ROME AH-240 LOT NUMBER 130 (A53084)
ROME AH-240 LOT...
