I want a bigger tractor, so I thought a chart might help me figure it out.
The best way to shop for tractors is to determine your tasks first, then determine how much bare tractor weight you need to SAFELY accomplish as many of your tasks as possible. Bare tractor weight is a tractor specification easily found in sales brochures and web sites.
Hillside work demands more tractor weight than flat land work. Heavier tractors have greater wheel spread making them more stable. Heavier tractors have larger wheels and tires better able to bridge holes and ruts without the tractor rolling over. Larger wheels and tires provide a much smoother ride over rough ground. Heavier tractors have greater inertia to resist rollovers when moving heavy loads in the FEL, the most hazardous of routine tractor tasks, especially hazardous on sloped land.
For most tasks greater tractor chassis weight is far more important than tractor horsepower. This tractor fundamental is difficult for people new to tractors to comprehend.
Shop your weight range within tractor brands. Budget will eliminate some choices. Collect a dealer brochure for each tractor model in your weight range.
Tractors under 3,000 pounds bare weight are offered in one configuration. Most, such as the high volume Kubota standard L series, are prosaically equipped to hit competitive price points. Others, such as the Yanmar YT235 and Kubota B2650/B3350 series, are splendidly adorned.
Most tractors under 3,000 pounds bare weight are operated in residential applications on one to five fairly
flat acres. These "residential tractors" fit in a typical garage.
Tractors over 3,000 pounds bare weight are generally offered in a utilitarian configuration and a deluxe configuration, on a common chassis. Deluxe kit enhances productivity and operating comfort ~~~ but you have to pay. Many are too tall to fit in a typical garage, even with ROPS folded down.
I like to spreadsheet tractor and implement specs, often a revealing exercise. I have a column for cost per pound.
It takes a 50% increase in tractor weight before you notice a significant tractor capability increase. It takes a 100% increase in tractor weight to elicit MY-OH-MY!
Selling a used tractor is easy. Selling multiple light implements in order to buy heavier, wider, implements for a heavier tractor is a pain and often a big hit in depreciation. ((Ask me how I know.)) Many who buy too light tractors buy too light implements.
A quality dealer, reasonably close, is a priority for me; less so for others, well experienced with tractors, who do their own maintenance. For most new to tractors a quality dealer, reasonably close, available for coaching, is essential. My kubota dealer is six miles away.
Horsepower is a primary consideration only operating PTO powered implements.
BUY ENOUGH TRACTOR.
I suggest your next tractor should be 2,600 to 2,800 pounds, bare tractor. Tractors in this weight range will have 12" to 13" ground clearance. A 25-horsepower, 100 cubic inch displacement tractor engine can spin a 60" wide Rotary Cutter through dry 18" grass at normal operating speed. Can cut slightly taller grass at very low speed.
More horsepower on same 2,600 pound to 2,800 pound chassis will allow you to mow faster and an increment taller grass.
Is mowing the only task(s) you foresee? I think not.
