Welcome to TBN. You don't list what you've tried or whether it's ever run for you. Do you have voltage to the coil? Do you have spark from the coil? How are your points? Is the gap correct? How about the timing? Is your distributor cap any good? How about the rotor? Are the spark plug wires correct for the proper firing order? How are the spark plugs? Did you check the gap?
