Massy F40 not starting
   / Massy F40 not starting #1
Redssubman
Massy F40
I just replaced the starter, now the tractor cranks but will not start.
   / Massy F40 not starting #2
Welcome to TBN. You don't list what you've tried or whether it's ever run for you. Do you have voltage to the coil? Do you have spark from the coil? How are your points? Is the gap correct? How about the timing? Is your distributor cap any good? How about the rotor? Are the spark plug wires correct for the proper firing order? How are the spark plugs? Did you check the gap?
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
Flatbed Trailer (A51694)
Flatbed Trailer...
2022 SIDUMP'R 48FT TRI AXLE SIDE DUMP TRAILER (A54607)
2022 SIDUMP'R 48FT...
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
