masseyferguson 50 oil pressure
   / masseyferguson 50 oil pressure #1
brittboy1
1964 massey ferguson 50
have a 64 50 series gas no oil pressure at idle usually around 10 at high rpm around 20 usually 30 rebuilt 1 year ago any suggestions would be appreciated
   / masseyferguson 50 oil pressure #2
Was the oil pump rebuilt or replaced when overhauled? Maybe the pressure relief spring broke? Or the seat is cracked. Did it go all at once or over time?
oil pump was rebuilt still has some pressure at higher idle about 15 pounds we cleaned the screen and checked the spring had alot of gasket material like a sealent in the screen know its better but not like it was
   / masseyferguson 50 oil pressure #4
15lbs at idle and 30 at 2000 rpm is pretty much normal on them
Continentals
checked it again has 5lbs at idle 20 lbs at 2000rpms is this enough to use the tractor need to get the garden in thanks for the help
   / masseyferguson 50 oil pressure #6
Manual for TO35 with Z134 says minimum 10-15 lbs at idle, 20-30 lbs at 2200 rpm. Is your oil pressure gauge reliable ?, if so i think your relief valve needs shimming.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A52377)
2014 MultiQuip...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
