Massey hydraulic filter.
   / Massey hydraulic filter. #1
Walt44
Livingston, Texas
Kubota L3010 GST /w/ LA 481 Loader, RTV x900
A friend has a Massey 245 and wants to know:
1. Does this tractor have a hydraulic filter if so where is it located.
2. How do you change the filter?
I told him that this site would have someone who would know the answers to his questions.
   / Massey hydraulic filter. #2
The filter is inside the transmission, on the right side behind the side cover (the best that I can remember). It is a wire mesh filter, that hardly ever needs attention.
   / Massey hydraulic filter. #3
It has a metal strainer attached to the 3pt hitch lift pump. There should be a triangular shaped cover underneath the differential housing. Three bolts secure this. If this cover is not there you will have to remove the left side cover where the pto lever is located. The trans/hydraulic fluid will need to be drained to service the strainer. The fluid capacity is 8 gal. If it has factory installed auxillary hydraulics there will also be a filter to the left of the seat that can be serviced.
Thanks for all of your help, I will pass this information along.
Wolverine Quick Attach Hydro Slide Pallet Forks (A50514)
Wolverine Quick...
2012 BOBCAT E80 EXCAVATOR (A51242)
2012 BOBCAT E80...
2005 International 7400 Chassis Truck, VIN # 1HTWGAAT75J048748 (A51572)
2005 International...
2015 Toro Z Master Professional 64in Zero Turn Mower (A50322)
2015 Toro Z Master...
Wovlerine Quick Attach Bale Squeeze (A50515)
Wovlerine Quick...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
