Massey HARRIS 44 wide to narrow swap
   / Massey HARRIS 44 wide to narrow swap #1
fidowanttobe
Platinum Member
Mandan ND
Jinma 284 2007 Massey Harris 44 Special
Hi guys, Is there anyone that can tell me what is involved with swapping a narrow onto a wide tractor? Yes, I know, usually is the other way around but my 44 row crop has an aftermarket belly blade on it so decades ago a combine rear axle was swapped onto the front for clearance when angling the blade. That works fine except with the added wheelbase I da#@ near have to take it to the airport to turn it around. I bought a salvage narrow front and rims, now I wondering what else if anything I will need. Any MH fans out there with advice? Thanks in advance.
   / Massey HARRIS 44 wide to narrow swap #2
Should be easy as pie . Where the steering connects under the center of the tractor is where the narrow front will fasten nothing else needed except maybe different length of bolts
Hay Spear for Tractor (A51573)
Hay Spear for...
2024 JOHN DEERE 3039R LOT NUMBER 165 (A53084)
2024 JOHN DEERE...
Yale MPB040-EN24T2748 4,000lbs Electric Walk-Behind Pallet Jack (A51691)
Yale...
2024 Kubota L3302 4x4 Tractor with Backhoe (A51573)
2024 Kubota L3302...
KUHN SL124T LOT NUMBER 63 (A53084)
KUHN SL124T LOT...
WOODS RT48.30 LOT NUMBER 235 (A53084)
WOODS RT48.30 LOT...
