Massey HARRIS 44 wide to narrow swap
   / Massey HARRIS 44 wide to narrow swap #1
fidowanttobe
Platinum Member
Mandan ND
Jinma 284 2007 Massey Harris 44 Special
Hi guys, Is there anyone that can tell me what is involved with swapping a narrow onto a wide tractor? Yes, I know, usually is the other way around but my 44 row crop has an aftermarket belly blade on it so decades ago a combine rear axle was swapped onto the front for clearance when angling the blade. That works fine except with the added wheelbase I da#@ near have to take it to the airport to turn it around. I bought a salvage narrow front and rims, now I wondering what else if anything I will need. Any MH fans out there with advice? Thanks in advance.
   / Massey HARRIS 44 wide to narrow swap #2
Should be easy as pie . Where the steering connects under the center of the tractor is where the narrow front will fasten nothing else needed except maybe different length of bolts
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
Coleman Go Cart (A51573)
Coleman Go Cart...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
