chemtimh
Had to get a new alternator on a 12V positive ground MH 44. I did a quick negative ground conversion by swapping the leads on the coil and the amp gauge and the battery so I could get a new 12V negative ground alternator with an internal voltage regulator. I disconnected the old voltage regulator. Now when the starter button is pressed the starter makes a single click and the big cables (even the battery frame ground) get very hot in just a second or two, and so does the starter.
I removed all the big cables and bought new ones, cleaned the surfaces and bolts they mount to, and had the battery tested. No diff. Now every wire, big and small, on the tractor is brand new and every connection has been cleaned, even the lights.
Yesterday this was a positive ground 12V tractor that started fine but had a bad alternator. Today it is a negative ground tractor that has a problem getting current to the starter. I did not touch the starting circuit when swapping out the alternators!
Suggestions please. What could cause this apparent overdraw of electricity, and why would it happen on conversion to negative ground?
