Massey gc2300 radiator cap
   / Massey gc2300 radiator cap #1
RobbyB
GC2300
Has anyone found a third party replacement radiator cap? I dropped mine inside the machine and cannot find it. Dealer wants $42.00 for replacement. I would guess that somebody offers a replacement from Stant or other manufacturer. I assume that this is a 7psi rated cap?
   / Massey gc2300 radiator cap #2
I replace my radiator caps about every 3 years no matter what because the internal spring looses it's spring tension.
I always buy OEM however.
Starting batteries every 5 or sooner as well.
I quess nobody has had to replace their radiator cap. Or if they did they went OEM?
   / Massey gc2300 radiator cap #4
Still working on the original radiator cap here.
KC
Thanks Willy, The problem I am having is that none of these items cross reference to the Massey 4264789M1 part number. Unfortunately I have not been able to find spec's on the 4264789M1 part for size, number of tangs and pressure ratings. I hope someone on here can provide some additional details. I called local dealer and he has one but at $55.
Looking at the picture of Massey 4264789M1 it shows 1.1 bar which translates to 16PSI. Plunger looks to be about 1" diameter. and it is a two tang cap. So it looks like I am off to the parts store to see what might be compatible.
If I find something I will post it here of others information.
   / Massey gc2300 radiator cap #9
I would just look for the cap couldn't have gone far...
   / Massey gc2300 radiator cap #10
Raf caps are one of the least replaced items on anything including cars and trucks. Again the issue with them is the heat and cool cycles weakens the spring and weak springs won't hold coolant pressure and coolant needs to be pressurized to work properly.
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
2016 Nissan Frontier Ext. Cab Pickup Truck (A50323)
2016 Nissan...
2007 Freightliner School Bus (RUNS) (TITLE) (A50774)
2007 Freightliner...
2013 Ford F-250 Animal Control Truck (A50323)
2013 Ford F-250...
2015 Caterpillar D6K Crawler Tractor Dozer (A50322)
2015 Caterpillar...
2013 Chevrolet Equinox LTZ AWD SUV (A50324)
2013 Chevrolet...
