cdaigle430
Veteran Member
I use mine for snow removal as well, till wish for a bigger snowbucket-I know the tractor can handle three times as much snow as the bucket will allow.
jc21, both Kubota's and M-F's SCUT blowers are made by the same company in Canada, RAD. I think they make blowers for others as well.
As far as their high price, maybe twofold:
1) To mount them, you need the "quick-hitch assembly" to hang on the front frame cross-member; this is a fairly heavy-duty piece of iron that includes a couple pillow-block bearings, a u-joint, the hydraulic lifting piston, and a short coupler shaft to go back to the mid-PTO -- and, of course, that mid-PTO driveshaft, too. (The quick-hitch assy. is the part that seems to be most brand-specific.)
2) The blower itself is also rather heavy-duty, though I think there's some room for improvement, but overall quite ruggedly put together. And remember, it's not made in China but North America, where labor costs are higher, presumably. Repair parts are no problem; I even have some Kubota parts (NOO!!) on mine.
The whole thing is steel; no composite on mine at least, save for the polyethylene rotation "bearing" under the chute and another similar sleeve bearing on the chute rotation worm drive. The one thing a few of us have done --and it made a huge difference on mine-- is to line the output chute with 1/8" ultra-high molecular weight polyethylene sheet. I also lined the circular impeller housing as well.
In the years I've had mine, it rarely slows down when blowing; the thing really has some power. Typical snow throwing distance is about 50' (no kidding!) for dry snow, 25'+ for wet stuff. By raising the blower up and attacking a high, snowplow-left, crusty old snowbank, I can go in slowly, remove the top layers, then lower the blower to clean it out right down to the ground. I've also been known to dive in at ground level until the blower's buried, then raise it and break the top layer(s) off so they fall to the ground, then back up and hit it again. It's really that strong.
Yeah, I've had a few bent pieces now & then by pushing it too hard or picking up an occasional ^%$# rock or two, but it's still going strong after 7 years.
Mine also came with the electric chute controls, and I like that a lot. Much slower than hydraulic, but better than the hand-crank system IMHO.
Ray, thanks for posting that pic; I knew you had one!
Walt (irvingj)
axlehub....that is a great idea, any idea of the weight of the massey blower?
