Massey GC 2310 now with HEAT!
   / Massey GC 2310 now with HEAT! #1
JMynes
Auburn, Maine
Massey 2310
I got tired of eating twice-blown snow, so I got the local Massey dealer to install a cab on the GC2310 and hydraulic chute rotator on the Puma. Found a heater on eBay, it's either the Maradyne 5000 or a clone. The day the tractor was ready, the heater came in the mail.
I spent a cold Sunday morning plumbing the heater up. I plumbed in to the water pump/thermostat bypass loop. On the little Iseki engine a 3/8 hose fit loosely, but 5/16 fit perfect. Some brass barb fittings and a couple of brass 1/2" threaded couplers, and I had it adapted up to the 5/8 pipes on the heater.
It was a hurry-up job just to get it working before the storm, and is not in it's final form. I'm going to add a diverter valve and tee so I can shut off the flow to the heater in the Summer, and I have to wire up a SPDT toggle for the two speed fan.
It doesn't throw massive heat, but it certainly keeps the cab warm. I think the 5/16 hose might be too small for massive heat, although, grabbing the brass fittings to check the temp shows it's plenty hot.
My opinion is that the bypass is the best spot to plumb in to for a cab heater. Any and all heat the engine puts into the coolant goes through that bypass until such time as the thermostat opens, and the flow through there stays hot after that. Plumbing into the radiator hoses can delay heat until the thermostat opens, not my idea of fun.
   / Massey GC 2310 now with HEAT! #2
Could you post some pics of the heater plumbing to & from the heater?? We are going to do the same with our 1523.
Thanks, and congrats.
I plan to put some pictures up soon, but not until I get it in it's final form. Like I said, It was a rush job just to get it working.
Probably finish it up next weekend if the weather is nice.
The plumbing is still not done, but here are some pics of the connection to the bypass. I removed the air cleaner for the pictures, when hooking it up I also drained the radiator and pulled the end of the upper radiator hose for better access.
There's also a picture of the switch box I made from off the shelf parts. The box is from Radio Shack, switches from TSC, and the 6 circuit fuse panel (inside box) is a generic Buss product.
So far I like how it came out. Still got to pretty it up some, but it all works!
   / Massey GC 2310 now with HEAT! #5
OMG :mad: Another project! I gotta get heat by next winter. Is that the MF cab? Could you post Pix of the cab also... Don't ask I'm already jealous. :D How do I tell the wife I want to spend more money on the tractor? Heat would be Neat, I'm a poet and don't know it.
   / Massey GC 2310 now with HEAT! #6
Pretty good job getting heat,considering the 2310 has the radiator, engine mounted backwards,less chance of heat being thrown back toward operator. I traded my 2310 for a 1531. It has the engine,radiator mounted the conventional way. It throws heat towards the operator,fine in winter,not so good in summer. plowking
Can't help you with the wife, I don't have one of those. That's one upgrade I'm just not going to install.
It's a Curtis Cab, couldn't find a source other than the Massey dealership. The dealer in Northwood seems to know about them, we talked about the cab among other things.
The heater is from ebay, much less dinero than the one the dealer was pushing.
Here are some pics. One of the tractor with cab. The other is how I used to have to dress. I can't snowblow in a t-shirt, but a light jacket is much better than the layered Yukon rig I had to wear.
   / Massey GC 2310 now with HEAT! #8
Great looking tractor. Although I do not have a MF, my JD 455 has the reverse engine layout like yours. The heater is just fair if it is cold out IF I do not block off 80% of the rad with a thin piece of cardboard. Makes a huge difference. When the temps get warmer I remove the cardboard as the temp gauge starts to climb. I also installed a 185* t'stat vs the 160* oem. My cab is hardsided JD but the heater is three speed I picked up from Princess Auto back in 2001. Has worked well and it makes blowing snow pleasureable. If it is really cold I block off rad 100%. I am surprised at how these small diesels run so cold.
Brian
   / Massey GC 2310 now with HEAT! #9
These small idi diesels have two issues.
1. They run a 160 T stat because if you start the engine and lean on it hard before the thermostat opens you take a chance of overheating the pre-chambers and cracking the head.
2. The radiator fan moves so much air it actually super cools the engine especially on colder days. I found that the engine temp won't get above 142 on a 20 degree day with the amount of air the fan moves.
I replaced my radiator fan with a 12" electric fan that turns on at 185 and off at 160. This gives me great heat and lets me keep the 160 T stat for coolant flow.
I like the electric fan idea.
My former boss has a tractor like mine, a 2300, and was concerned about moving snow and the possibility of plunging a hot engine into a cold snowbank and breaking stuff. I told him after working it hard for a couple of hours in the winter I was able to grab and hold onto the upper radiator hose, warm to the touch, but certainly not hot.
I kind of suspected that big direct drive fan was VERY effective.
What make and part number is that electric fan? Does it come with a switch? Where does the switch go?
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
CAT 973 (A47384)
CAT 973 (A47384)
2005 Mack Vision Semi Truck (NOT RUNNING)(TITLE) (A50774)
2005 Mack Vision...
Ez-Go Shuttle 2 Electric Golf Cart (A50121)
Ez-Go Shuttle 2...
Marliss Grain Drill (A50120)
Marliss Grain...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A52748)
2023 NEW HOLLAND...
