Massey Fergusson
   / Massey Fergusson #1
Tonyp
Ontario, Canada.
2010 MF 1643
Selling an early 70's 135, 2500 hrs, and a 1010 with 4300hrs in Ontario. Both in working condition. Any one have a value on these?
   / Massey Fergusson #3
Regrettably, I can't help you with pricing. But if you post your thread in the MF forum, you most certainly will get more replies. While you're there on the MF forum, you may find some info there.:tractor::welcome: Good Luck.
   / Massey Fergusson #4
Welcome to TBN. Where in Ontario are you located. I have a Massey 1020.
I'm not sure on a price for the 135 but for the 1010 a range from $4000 to about $6500 depending on what comes with it. Other things on the 1010 that will affect the price are if it has four or two wheel drive, the type and condition of tires / ballast, a loader, hydro or standard transmission and the year.
   / Massey Fergusson #5
In July 2006 I paid $3600 for a 1964 MF135 diesel deluxe with multipower and 4600 hours showing. The engine had been rebuilt at 3000 hours. The original owner had been running a hydraulic pump off the front of the engine and snapped the crankshaft. Runs fine but has a few oil leaks and the 2-stage clutch has run out of adjustment and probably will need to be replaced soon.
Good luck.
   / Massey Fergusson #6
WELCOME to TBN :)
I moved your thread to the Massey Ferguson Buying/Pricing Forum.
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A53472)
John Deere 6105E...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
