Massey Ferguson
   / Massey Ferguson #1
Benwolfe
Coolville, ohio
135 massey ferguson
Dealt for a Massey Ferguson 35 and it has a 135 Perkins 3 cylinder, completely rebuilt. Its never been started, and I was told that they ordered a pump for a 35. I have the front case off of it and timed it and it wont hit a lick. I spray it with starting fluid and it starts and quits and wont run on fuel, and the pump is working and squirts fuel when I crack the lines. Need suggestions PLEASE!
   / Massey Ferguson #3
Greetings Ben from Tennessee. We have an active Vintage MF area you might pose your question. Welcome to TractorByNet.
Sent via Ipad2
   / Massey Ferguson #5
Welcome to TractorByNet!
We moved your thread to the Massey Ferguson Owning & Operating forum. :)
   / Massey Ferguson #6
Have you tried to bleed the air out of the fuel system?
I changed my fuel filter one time on a Perkins diesel and got air in the system. It was a pain to get the air out but once I followed the instructions I found somewhere on this site it fired right up.
Welcome and good luck.
Bleeding Fuel System
   / Massey Ferguson #7
Yeep, bleeding these systems is a pain, but generally straight forward. I reccomend you have jumper leads handy in case you flatten the battery as the hand pump is awkward to use. You get pissed off and use the starter instead. A rag to go on the hand pump lever will make it a bit more comfortable to use.
DoD 88-20041 12.5kVA Brushless Diesel Generator (A51691)
DoD 88-20041...
2019 KUBOTA L39 BACKHOE (A51246)
2019 KUBOTA L39...
2017 Snapper Pro 48in Zero Turn Commercial Mower (A51691)
2017 Snapper Pro...
2011 CATERPILLAR 140M2 MOTORGRADER (A51246)
2011 CATERPILLAR...
2018 CATERPILLAR 259D SKID STEER (A51246)
2018 CATERPILLAR...
