Massey Ferguson Tractor 243
   / Massey Ferguson Tractor 243 #1
bull1200
Ohatchee, Al
7000 AC
Having a bit of an issue with a MF 243 Tractor, Serial Number: J01401, Type 5567. This is a 2000 year model, I think.
Anyway, been a very good tractor. Don't work it hard, mowing and light stuff. It has a factory loader on it.
Had no problems and then was working and the loader stopped. Thought it was the valve. Nope. Thought it might be filter. Nope. Checked oil. Fine.
Can't seem to figure it out. Strange thing is the 3 pt lift arms work, but loader does not.
Called Massey, they said call dealer. Dealer was no help. I really don't think he has much experince with the 243. He couldn't even tell me if it had 2 hydraulic pumps or one.
This really seems to me to be "known" issue, for reasons I can't really put my finger on. But I can't seem to find anything on the web.
Like I mentioned, it has not been worked hard by any means.
Anyone have any ideas?
Also, is the 245 the same as the 243, just a later model.
Can't seem to find a service manual on the 243, but found one on the 245.
Thanks very much in advance.
   / Massey Ferguson Tractor 243 #2
The 245 is different. Older if I'm not mistaken. You may need to adjust the lift quadrant (the lever on the side that controls the tph). Also, make sure your draft control lever is all the way back. The 245 book should have the same procedure as the 243 for adjusting the quadrants.
The position control lever/quadrant is closer to the operator.
The draft control lever/quadrant is located closer to the fender.
   / Massey Ferguson Tractor 243 #3
Massey Ferguson 243
1999 - 2003 200 Three Series
Utility tractor
Manufacturer: Massey Ferguson
Factory: Coventry, England
Original price (USD): $20,050 (2003)
Massey Ferguson 243 Engine:
Perkins 2.7L 3-cyl diesel
Capacity:
Fuel: 12.7 gal [48.1 L]
Hydraulic system: 8.5 gal [32.2 L]
3-Point Hitch:
Rear Type: II/I
Power Take-off (PTO):
Rear PTO: live (two-stage clutch)
independent (optional)
Rear RPM: 540
Dimensions & Tires:
2WD Wheelbase: 75.1 inches [190 cm]
4WD Wheelbase: 76.1 inches [193 cm]
Weight: 5045 to 5130 pounds
Front tire: 6.00-16
Rear tire: 13.6-28
Massey Ferguson 243 Power:
Engine: 52 hp [38.8 kW]
PTO (claimed): 47 hp [35.0 kW]
Drawbar (tested): 37.7 hp [28.1 kW]
PTO (tested): 47.6 hp [35.5 kW]
Mechanical:
Chassis: 4x2 2WD
4x4 MFWD 4WD
Steering: hydrostatic power
Brakes: independent wet disc
Cab: Two-post folding ROPS.
Hydraulics:
Capacity: 8.5 gal [32.2 L]
Pump flow: 9.5 gpm [36.0 lpm]
13.9 gpm [52.6 lpm] (optional)
Total flow: 9.5 gpm [36.0 lpm]
13.9 gpm [52.6 lpm] optional
   / Massey Ferguson Tractor 243 #4
Massey Ferguson 243
Utility tractor
Manufacturer:Massey Ferguson
Factory:Coventry, England
Original price (USD):$20,050 (2003)
Capacity:
Fuel:12.7 gal [48.1 L]
Hydraulic system:8.5 gal [32.2 L]
3-Point Hitch:
Rear Type:II/I
Rear PTO:live (two-stage clutch)
Rear RPM:540
Dimensions & Tires:
2WD Wheelbase:75.1 inches [190 cm]
4WD Wheelbase:76.1 inches [193 cm]
Weight:5045 to 5130 pounds
Front tire:6.00-16
Rear tire:13.6-28
Engine:52 hp [38.8 kW]
PTO (claimed):47 hp [35.0 kW]
Drawbar (tested):37.7 hp [28.1 kW]
PTO (tested):47.6 hp [35.5 kW]
Mechanical:
Chassis:4x2 2WD
4x4 MFWD 4WD
Steering:hydrostatic power
Brakes:independent wet disc
Cab:Two-post folding ROPS.
Hydraulics:
Capacity:8.5 gal [32.2 L]
Pump flow:9.5 gpm [36.0 lpm]
Total flow:9.5 gpm [36.0 lpm]
The only way to know is to ask the dealer to look up the original sales receipt (from agco) or to open that lift cover up. The scotch yoke pump comes standard in most mf agricultural/utility tractors. The secondary pump is run off the front gear on the scotch yoke like timing gears on an engine.
Does your PTO cover have a horse shoe shaped hard pipe coming off of it?
Thanks very much for the replies from all.
Responding to jimmyhouser:
1. No pipe to pto.
2. Attached an image (or trying to), is the secondary pump the one which the arrow points to? Does the tractor have to be split to replace this pump? This pump has a line going out to the loader valve.
Thanks again for the help, guys.
Here is the image (I hope).
   / Massey Ferguson Tractor 243 #6
Yes, that's the auxiliary pump. Put the stand pipe back in the hole on the other lower pump. Stick a hose on top and loop it back down. Put about 3 gallons of oil (enough to cover the lower piston pump and it's filter) and fire it up at idle speed. Check the auxillary pump's hard pipes for leaks and be sure that flow is coming back through the side cover.
   / Massey Ferguson Tractor 243 #7
   / Massey Ferguson Tractor 243 #8
When you go to replace this cover, pull the position control and draft control levers back, so the walking beam is BEHIND the pump roller (on this particular model).
Make sure the relief valve isn't pouring.
There are 4 red dots I have placed for you to check out. The long pipe, check tightness and for leaks. The elbow fitting on top of the pump. The relief valve, make sure it isn't continuously pouring.
Also, the bent pipe coming back in through the pto shift cover. Make sure it is flowing. You can even use the loader functions and try to pop off the relief valve if that could be the issue.tapatalk_1518139309004.jpeg
   / Massey Ferguson Tractor 243 #9
If there's a bunch of greasy goop in the bottom you need to clean that mess out with a shop vac and rinse it with diesel fuel.
Sorry for the bombardment of posts.
Thanks very much for the information.
Will run those diagnostics.
Thanks again.
New/Unused 12ft x 7.4ft x 8.2ft Container (A51573)
New/Unused 12ft x...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
2013 Dodge Charger Sedan (A51694)
2013 Dodge Charger...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
