Massey Ferguson Sub Compact GC1723M Hydraulic noise
   / Massey Ferguson Sub Compact GC1723M Hydraulic noise
So I saw this post and I was experiencing the exact issue. I have a new 2021 gc1723eb and once warmed up a significantly loud squeal. It would only go away when I moved a hydraulic control lever. I noticed somewhere someone that had this issue found it disappeared after removing and reinstalling backhoe. Also read about hydraulic couplers being incorrectly installed so the 3 point hitch would not raise. So I removed my backhoe...and I also had hydraulic couplers incorrectly installed so my 3 point hitch would not raise. I reconfigured the couplers...3 point then raised. I exercised the 3 point hitch several times up and down. Put backhoe back on. I have used several hours since... no squealing. Is it possible that air was trapped and never removed from the 3 point hitch system causing vibration in the hydraulics ?. The hitch could not have been operated from factory the way the couplers were configured. So far so good. No squealing.
Jdolson
See my April 15th 2020 post - It is my understand a Hydraulic relief valve issue was my tractors problem - the spring was too long causing a higher regulated pressure then designed for and that the tech could not adjust out so the fix was to shorten the spring to get to the proper pressure. In my opinion due to the fact that your hydraulic couplers were configured wrong may have put a higher back pressure on the Hydraulic system causing the squeal and when you reconfigured the couplers the proper pressure was restored Also the wrong coupler configuration may have cause a restriction in the system to cause the noise
Hope this helps - again just my opinion
Jdolson
   / Massey Ferguson Sub Compact GC1723M Hydraulic noise #13
Man, what's up with the newer GC series tractors?!! It's like issues with this relief valve, and then the backhoe joystick housing was built all janky. I read about some various other complaints too. MF should get their crap together, and I will say I'm real happy with my older GC1710, had no problems with it!
I was kinda sorta debating (before hearing about all these issues) trading her in down the road for the new model, but no way!
(3) 8' High Pole Swinging Gates (A50515)
(3) 8' High Pole...
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
1994 Mack CH613...
2024 AGT INDUSTRIAL QHT-500FL CONCRETE BUGGY (A51243)
2024 AGT...
New Idea Manure Spreader (A50515)
New Idea Manure...
UNUSED JCT SKID STEER QUICK ATTACH TRENCHER (A51244)
UNUSED JCT SKID...
