3-Point Hitch Massey Ferguson MF 35 Utility Tractor Front end Loader
   / Massey Ferguson MF 35 Utility Tractor Front end Loader #1
jvb
winnipeg,mb
Massey Ferguson 35 Utility
I recently bought a 1960's vintage Massey Ferguson MF 35 Utility tractor; front end loader. Everything worked fine until the 3 point hitch started acting up. It works sometimes and some time not. The slider control on the right side works sometimes. What is the knob and other piece on the control about? Do they need some kind of adjustment? I'm not sure how the 3 point hitch is powered. I don't see any hydraulic lines running to it. I'd appreciate any advice some one has to offer.
   / Massey Ferguson MF 35 Utility Tractor Front end Loader #2
do you have a valve near your right leg under the seat? that valve if present could be in the wrong position.. Most utlilties came with a front pump mounted off the crank for the loader
There are 2 slider controls that come out from under the seat on the right side. One is marked Position and the other Draft. I can't get the Draft slider to move. A week ago when I had the problem I managed to move it slightly and next morning the 3 point hitch worked. Was it just coincidence or do I have to get the draft slider to move; ie is that the root of my problem?
   / Massey Ferguson MF 35 Utility Tractor Front end Loader #4
Do you have any hydraulic levers on top of the transmission between the shift levers and the seat between your legs?
   / Massey Ferguson MF 35 Utility Tractor Front end Loader #5
I would recommend you buy yourself a manual for that tractor. You can buy them at
Antique Tractors - Yesterday's Tractors : Parts and Online Community
I am not sure of the full details of the TPH mechanism, but I do remember a hydraulic filter that is inside the housing (below the driver seat) on my old MF65 - so I assume your setup will be the same. Maybe finding and cleaning the filter will help - it sure won't do any harm.
   / Massey Ferguson MF 35 Utility Tractor Front end Loader #6
jvb, I am not familiar with the particular model you have, but the basic operation of the two levers is as follows:
Position control means that the implement (or empty link arms) is in the position set by this lever - up, down or somewhere in between.
Draft Control automatically varies the implement position in order to maintain a traction power that is constant.
The draft control lever should be in the fully "up" position for the position control to work properly. If you cannot move this easily then identify the problem and fix it. Having the FEL on the ground and unable to raise it is quite a problem. The tpl as invented by Harry Ferguson did not have external rams to activate the lift arms.
If I remember correctly (and it was a very long time ago) a certain sequence of moving the two levers meant that the position control did not work at all if the draft was in the down position. Back is up, forward is down.
To be honest I never quite got the hang of operating draft controls to a high degree of competency. I always seem to set it to a depth that suits only part of the area I am working. Like many people I often rely on simply raising or lowering the implement via the position control, although I do use the draft at times, particularly with implements such as a sickle-bar type mower where the skid plate runs along the ground. Pushing both levers forward means that the implement "floats" on the ground. It is also possible to "mix" the control - slightly complicated but useful if ploughing land that has very light areas in it and where the plough might engage deeper than is necessary, or you want it.
There is a lot of info on the web about how these levers operate, but some of the articles are not well structured and assume that the reader has a grasp of the technicalities and language of tractor engineers.
   / Massey Ferguson MF 35 Utility Tractor Front end Loader #7
I believe I can help you. I have a 135 with a loader which is the successor to the 35. Massey hydraulics can be complicated when trying to run a loader and three point hitch. Some of what I write here is very basic info and not meant to insult anyone. The solution to your problem could be very simple. All hydraulic levers must be in the correct positions for everything to work properly.
First, is the trans fluid to the correct level. Dipstick is on right side of the differential by your heal when in the seat. You did not mention anything about loader operation, so it's hard to comment on those hookups.
Second, you may have a two stage clutch. Push down part way, you should feel spot that feels softer,this stops power to the rear wheels. Push down all the way to the floorboard and this stops power to the PTO and hydraulic pump.
You may have an auxiliary valve on top the transmission in front of the seat between your legs. If it is a two spool valve, the left lever has to be pulled and held by the detent to operate the three point. The right lever needs to be centered. Right lever can be used to operate a loader or other implements. Draft lever needs to be pulled all the way back and position lever in the constant pumping position. Three point and auxiliary can be operated separately and not at the same time.
You may have a diverter valve in place of the before mentioned auxiliary valve. This must be shifted in the correct position to operate the three point or other implement. When in the three point position, both draft and position lever need to be in the transport position to raise the three point.
If you have a separate hydraulic system running the loader with a front pump, it may be a more serious problem.
Post back and let us know how you make out.
SIMassey
   / Massey Ferguson MF 35 Utility Tractor Front end Loader #8
I don't know much about the hydraulics but have owned a 35 for 30 years and have had a couple of problems with the hydraulics that were easily fixed by someone who knew a bit about them. If you haven't already, I would suggest you change the hydraulic fluid so you know what you are working with. I think there is a hydraulic filter in the housing under the seat accessible from one of the side cover plates. If there happens to be a lot of water in the oil, it may work to some degree in the summer but will freeze up in colder temperatures. Big Dean was a MF mechanic for years and was a wealth of knowledge but has passed on . He had made some videos about MF tractors and repairs . Search him out and you may find more info about your tractor..
Al
Thank you to everyone who replied to my post. Your information has been very helpful. I definitely need to change the oil in the transmission. Found myself a manual online and printed it so I could actually read it comfortably instead of having to peer at a computer screen to study it. I can't actually work on it much these days. I don't have a heated shop and its been -35 degrees Celsius up here the last couple of days. Fortunately we haven't had a lot of snow yet and haven't had to use my snow-blower attachment yet much; chained it in the up position so I could take the tractor into the back bush and cut wood. The front end loader bucket is handy for bringing out cut up logs; the front hydraulics work fine; it has its own pump on the front.
   / Massey Ferguson MF 35 Utility Tractor Front end Loader #10
Now that we know you have a separate system for the loader, I have to believe the only levers that control the the hydraulics are the position a draft levers on the right hand side of the seat. Having the temperature swings we have had from fall to winter may point to water in the oil. If there is a filter screen in the 35 it may be frozen and restricting flow to the pump. Hopefully there is not enough water to freeze and cause more damage elsewhere. First warm up get it drained! Getting that draft and position freed up will be key for proper full three point operation also.
2015 WESTERN STAR 4900 SF (INOPERABLE) (A45333)
2015 WESTERN STAR...
CAT 420F IT BACKHOE (A45046)
CAT 420F IT...
New/Unused H15R Mini Excavator (A44391)
New/Unused H15R...
2009 Ford F-350 Utility Truck, VIN # 1FDSF30519EA55749 (A44391)
2009 Ford F-350...
FREIGHTLINER FUEL TANK (A45046)
FREIGHTLINER FUEL...
2014 Mercedes-Benz C-Class Passenger Car, VIN # WDDGF4HB1EG240849 (A44391)
2014 Mercedes-Benz...
