Massey Ferguson info
   / Massey Ferguson info #1
Gem99ultra
Elite Member
Mid-Georgia
Kubota L3400HST
I'm trying to help a mechanically challenged neighbor with his old Massey Ferguson, and need the data for it. It is a MF 135, 3 cylinder Perkins Serial Number 9A45442.
I know at minimum that I'll need to replace the water pump, and who knows what else. Can someone at least get me started locating parts with the year of the tractor? Any other spec's would also be most appreciated.
The TractorData.com site only goes up to 1975.
Thanks,
Jim
   / Massey Ferguson info #2
There is a lot of data on the MF135 online. Do a search on this site, yesterday's tractor etc. You will easily find what you need online or through your local Massey dealer. I have no trouble getting about any part for my old Ferguson TO20 and that 135 is newer and one of the most popular models Massey built.
With the model and serial number you will find anything you need.
Very true about parts availability. I have a lot of respect for trusty old Massey's - fine workhorses for sure. My dilemma however is that I have not found anything online listing model numbers past 1975. The neighbor that I'm trying to help 'thinks' its a 1974... or a 1979... hmm - not exactly sure :) Nor am I.
   / Massey Ferguson info #4
Yes, I see what you were asking. I looked for a bit and found this reference that would seem to indicate the 135 in question is a 1975 based on your (tractor not engine) serial number. This states the 135 had an 11 year production run with 1975 being the last year.
Serial Numbers And Data « Vintage Massey Ferguson 135 .com
Do you have a local Massey dealer? If so, take the number to them and I would think it would get sorted out and confirmed pretty quick.
   / Massey Ferguson info #5
What's the tractor doing? Is it running? Any excessive exhaust smoke? Any tranny problems? Clutch problems? PTO problems? 3-pt hitch problems? Any funny noises?
Most important problem is the water pump is leaking. Then there are a number of steering linkages that are sloppy and need to be replaced. The tractor is a very good ole' horse. I'm not wanting to do a total restoration, but only to make it mechanically solid. No major repairs that I can see are needed.
   / Massey Ferguson info #7
OK. Glad to hear that 135 is in good shape.
Massey Ferguson is part of the agricultural equipment giant AGCO. You can get parts for that 135 from them
AGCO Parts
I replaced the water pump seal on my 1964 MF135 diesel a few years ago. Not difficult.
Good luck
   / Massey Ferguson info #8
You don't need to find data beyond 1975. 7 digit serials like yours ended sometime in 1970. Your neighbor's machine is a 1968.
Scott in Brighton NY
   / Massey Ferguson info #9
1964: 641000001
1965: 641001909
1966: 641014871
1967: 9A10001
1968: 9A39836
1969: 9A63158
1970: 9A87325
1971: 9A107519
1972: 9A128141
1973: 9A152025
1974: 9A182761
1975: 9A207681
1964: 641000001
1965: 641001909
1966: 641014871
1967: 9A10001
1968: 9A39836
1969: 9A63158
1970: 9A87325
1971: 9A107519
1972: 9A128141
1973: 9A152025
1974: 9A182761
1975: 9A207681
Excellent info; Thanks!
There was another message above describing the transmission pre-1973 was a 3/6, so the BS the owner got about it being a 1974 was exactly that. Now, on with the fixing up :)
Many thanks to those that contributed info.
STORAGE FEES (A54313)
2018 Chevrolet Tahoe (A51694)
2018 Chevrolet...
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2018 FORD F-150 (A53843)
2018 FORD F-150...
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A53843)
2013 KENWORTH T800...
