Front-End Loader Massey ferguson industrial 30
   / Massey ferguson industrial 30 #12
Allis Chalmers 185
I stand by what I said, the Allis has a larger pump built in "stock" than the pump in the transmission of the Industrial 30.
If "this tractor" (which I probbaly should have clarified meant the MF 30 Industrial) DOESN'T have a front pump, it will be very slow as I said.
I tried to find some specs on the pump that fits the Ind 30 with no luck. The aftermarket pumps that fit don't give any specs as to the flow rating and a lot of them don't come with a relief valve. If the OP needs to know exactly might could go to agro and find out. As long as it works for what you want then it's good.
This one claims 21GPM at 2000RPM: 275128M91 Front Mount Hydraulic Pump Made To Fit Massey Ferguson 3 32 4 54 212: Amazon.com: Industrial & Scientific
The stock pump on Dad's MF Industrial didn't have a relief valve in it AFAIK, it relied on the one in the loader valve mounted on the RH loader frame/tank.
Aaron Z
   / Massey ferguson industrial 30 #13
Aaron Z
I will say this, many older farm tractors had add-on loaders that worked fairly well. This includes some older mf tractor. I will say the mf tractor in question I'm not really familiar with, so difficult for me to say one way or another. That being said, koyker, westendorf and farm king have always been the add-on loader of choice around here for old tractors. From your point of view, this particular tractor may need to make sure there is sufficient hydraulics or a way to upgrade the hydraulics to handle a loader. I had a allis Chalmers D-15 that someone had modified with a home made reservoir and a pump to improve its hydraulics. Like I say, this particular mf tractor I'm not totally up to speed on.
   / Massey ferguson industrial 30 #14
I've got a MF35 Utility, came factory painted yellow and with a loader. It's from 1964. Internal pump is only 4.5ish gpm. It'll run a loader, but slooowwwlly. Most of these older Masseys came with a front mounted SAE Type A hydraulic gear pump, mine is made by Cessna, but others are fine too. The relief valve is in the loader's spool valve. I personally wouldn't bother with the internal pump, however you can find a suitable pump on surpluscenter.com that'll meet your needs for much less money.
You'll want something between 12-17gpm, generally the spool valves will flow around 20gpm. Make sure it flows that specified number at a reasonable RPM. You don't want to be pinned at 2k RPM to get the flow you need to run the loader efficiently. I'd base it off of around 1200rpm/ PTO rpm.
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2009 Kubota RTV-1140 4x4 Diesel Utility Cart (A55851)
2009 Kubota...
JMR stump/trenching bucket (A53421)
JMR...
2019 KUBOTA SVL95-2S SKID STEER (A52707)
2019 KUBOTA...
JCB 2145 (A47477)
JCB 2145 (A47477)
Ammco Brake Machine (A55758)
Ammco Brake...
