Massey Ferguson GC2610 TLB Battery problem, need help.
   / Massey Ferguson GC2610 TLB Battery problem, need help.
Didn't know that. Thank you for the info.
I would check wiring from alternator to battery including grounds. If that all is good probably time to replace alternator or have it rebuilt.
Will do, thank you!
Thank You.
   / Massey Ferguson GC2610 TLB Battery problem, need help. #14
I have a gc2300. Should be 99% the same
I had a problem with mine where the battery would go flat and occasionally stall for no good reason.
There is a ground wire from the engine block to the frame. It's about as thick as my baby finger.
Just looking at it, it appeared fine.
But at the point where the wire is crimped on to the eyelet bolted to the frame the wire was cracked/broken.
The wire is stiff enough that it didn't fall down but was only making partial contact.
Enough to start and run when the battery had enough charge but when it got run down it would die.
In the middle of cutting around the garden she died. Started to give it a good luck when I finally noticed the bad contact by mistake.
Replaced the grounding cable and Bob's your uncle. It's down on the side around the bottom of the block. Without going out to the barn and taking a look I forget which side. Just a heavy ground wire about 8+ inches.
Whenever I have an electrical issue I look for the easiest solution first.
Dirty corroded contacts, bad wiring etc.
This one was so obvious but almost got by me.
Thank you for the information. Really appreciate it. Have a great day.
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
3ft Toolbox (A57454)
2008 INTERNATIONAL MA025 FLATBED (A55745)
2008 INTERNATIONAL...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
