Massey Ferguson 6180 Hydraulic problem
   / Massey Ferguson 6180 Hydraulic problem #1
54farmall
pendleton, or
farmall Super M
Hi All,
I am new to the forum. I have a vexing problem with my MF 6180. After working the tractor for about 20 minutes, the (Transmission oil filter warning light and lubricating pressure warning filter warning light) comes on. I am not certain what to do about this. I have changed the filters, and took it to the dealer, and they put a new hydraulic pump in it (i just bought the tractor and the dealership did this on their own dime, which I found to be great service). However, when driving it home, the light came on after about 30 minutes of driving. ---- Other notes: The tractor is stuck in 4WD - and the dealership also changed the seals on th 4WD mechanism when they replaced the Hydraulic pump.
I am not sure if I have a sensor problem or a Hydraulic fluid flow problem or what the deal might be. Seems to be worse after warming up, however. The light comes on much more quickly if I have recently used the tractor and just turned it back on versus sitting overnight and starting work.
Thanks ahead of time for any thoughts.
   / Massey Ferguson 6180 Hydraulic problem #2
Hi,
Did you solve your problem with your 6180? I have the same issue here with my tractor.
   / Massey Ferguson 6180 Hydraulic problem #3
G'day the first thing to do is change the hyd filters you have 1 or 2 suction filters and a high press filter in a steel canister there is two different versions of those too you will have to remove it and check the length.
Jon
2008 Chevrolet Suburban SUV (A51694)
2008 Chevrolet...
2020 COLOMBO TM LOT NUMBER 217 (A53084)
2020 COLOMBO TM...
378577 (A51573)
378577 (A51573)
1990 JOHN DEERE 544E WHEEL LOADER (A52472)
1990 JOHN DEERE...
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A51572)
2005 Hino 268...
2014 PETERBILT 579 SLEEPER (A52576)
2014 PETERBILT 579...
