Massey Ferguson 50 clutch kit Questiuons
   / Massey Ferguson 50 clutch kit Questiuons #1
Amherst Wisconsin
Ford 641 / 1963 Fordson Super Major
I have a Massey Ferguson 50 split to replace clutch and pressure plate. Looking for best options for a new clutch and pressure plate kit. The pressure plate has broken bolts and spring pieces that hold the 3 fingers.
11" clutch - tractor serial # 633344 -
One big question - in my manual it references specialty tools for adjustments to clutch fingers, and pto clutch settings...
If I get a clutch kit, are these preset?... Or do I need to adjust these before installation?..
I've called and asked one supplier, and was told they are preset, ready to go. But, everyone is a salesman. Is this really true? Or do I have to adjust everything before it is ready to instal?
Can someone verify this? With details please!
Thanks you.
   / Massey Ferguson 50 clutch kit Questiuons #2
Last clutch I put in was on a mountain side coming out of rapid city SD in 6" of snow. Did it overnight. Without a transmission jack. Every one I ever put in was pre set.
   / Massey Ferguson 50 clutch kit Questiuons #3
been about 35 years since I did a clutch but aren't the adjustments for when you replace individual components while "KITS" come preset??
Thanks for your experiences guys.
I was told they are preset, ready to go. Just trying to cover the bases before I get a replacement, and or waste time not knowing for sure. This one is obviously defective, and wanted some clarity before I order another. I tried tinkering with it to get it to work, but not happening.
I drove and returned and replaced the clutch kit today. They said it was probably a bad one. So, I got another one that did in fact look different, in some respects, so I was hoping it would work.
No such luck! Same as before. It bolts on but the fingers pull in tight when I tighten the bolts down.
Not sure what to try next.
I just don't think this is the right clutch kit. Very frustrating!
I just think it is too thick, and not working properly.
John Deere 535 Discbine (A49251)
John Deere 535...
275 Gallon Liquid Storage IBC Tote (A49346)
275 Gallon Liquid...
2006 PETERBILT 379 (A48992)
2006 PETERBILT 379...
Bush Hog 180in Triple Deck Pull-Behind Bat Wing Mower (A49346)
Bush Hog 180in...
2017 FREIGHTLINER M2 DAY CAB (A45679)
2017 FREIGHTLINER...
9054 (A48837)
9054 (A48837)
