Massey Ferguson 4235 Power Shuttle 12 x 12 Transmission question
   / Massey Ferguson 4235 Power Shuttle 12 x 12 Transmission question #1
jpjahn
Davenport,WA.
Case 1835B
I have a 1997 4235 MF with a power shuttle that moves in forward (Low and Med ranges but struggles to move in High range). It shows error code 4 -2. When I shift to reverse it drives normally and the error codes go away. I have checked the electrical connections on the two solenoids and pressure sensors under the operator's platform, they seem to be ok. The tractor has approximately 2900 hrs, on it and the tractor is new to me. The hydraulic oil level is in the normal range, the oil seems to be thin to me but not sure if that is normal for the Permatran 3 oil that is recommended?
Does anyone have any insight on what I should check?
   / Massey Ferguson 4235 Power Shuttle 12 x 12 Transmission question #2
I am not familiar with that model or how the transmission works, but my guess would be that the forward clutch has a bad sealing ring causing pressure loss resulting in the clutch slipping on the higher gear.
Thanks,
Does anyone have any information as to where to get a repair manual online? Anyone have any experience with Manualboss or Servicemanualbit?
Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A50322)
Toro Z-Master 6000...
Harlo HP8500 Forklift (RIDE AND DRIVE) (A50774)
Harlo HP8500...
Bad Boy 747cc Outlaw (A50121)
Bad Boy 747cc...
2020 Cadillac Escalade 4x4 SUV (A50324)
2020 Cadillac...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2013 Mack GU713 T/A Vac-Con Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
