massey ferguson 35
   / massey ferguson 35 #1
countrymountainroad
tennessee
none
Can someone help deciphering the serial number. it is supposed to be all original. the tag says model TO 35 SDM198921. Which would be standard chassis standard 4-cylinder diesel A two stage clutch but what's in it is the 3 cylinder Perkins and the body style of a Massey Ferguson 35 with the pointed Grill. i would like to buy some parts not sure what to buy parts for. i think I'm confusing my self with all the info between the TO TE FE MF and all the other things with the 2 companies merging brands. i have a picture I'm gonna try and load it up if it will help. its red and Gray and says Massey - Ferguson 35, tri star MF hood badge, and. sticker that says Massey power or something.
https://i.imgur.com/kQBUmTJ.jpg
   / massey ferguson 35 #2
G'day Mate and welcome to TBN from Downunder.
This could be your version, the serial number looks to fall in in line: TractorData.com Massey Ferguson 35 tractor information It really was a hodge-podge when the companies amalgamated... especially when they were trying to use up stocked parts on the early models
Enjoy the site.
   / massey ferguson 35 #4
They would have built 60 model tractors in 59 .
ok here are a few photos to help with identification. please let me know if the link doesnt work. I'm trying to do some maintenance and buy a manual on it but keep getting the wrong parts. I would like to drain and fill the rear dif hydraulics but I guess there is a difference between the mf and to 35 as far as how much and what kind of fluid to put in. more people said to put in straight 90w gl1. every time I want to buy something it generally depends up to or from on the serial number which is supposed to be all original. finally got the right fuel and oil filters. the gauges and tractometer are all miss match or rotted and I would like to put the correct ones in. couldn稚 find anything on the serial number or casting number of the engine block. Was hoping it would give some help as to the year or if it was replaced. is this thing just what was left over on the end of the line during the merger. any help would greatly appreciated as the parts store is all the way in town. If any one needs any other photo or something just ask.
massey ferguson 35 - Album on Imgur
   / massey ferguson 35 #6
That number starting with SDM is your tractor's serial number. If you go to the Yesterday's Tractors web site and look at the left hand column under Research & Info, there is a section on serial numbers. You can search that and get an idea of the year.
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
2012 CATERPILLAR 308E CR EXCAVATOR (A51246)
2012 CATERPILLAR...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
Single Axle Rear Truck Frame (A51692)
Single Axle Rear...
2013 KENWORTH T800 DAY CAB (A53426)
2013 KENWORTH T800...
