Massey ferguson 3080 won't start
   / Massey ferguson 3080 won't start #1
Nerijus01
(There may be spelling mistakes, not my language)
I was preparing a field for crops, using disc harrow, i kept the rpm at around 1.8k, after a few hours tractor started emmiting black smoke, i was thinking that the ground was more wet and didn't pay much attention to it, once i stopped the rpm was only 600, i decided to go home, but when trying to put down the wheels for driving the tractor's engibe stopped, it started no ptoblem, but i turned it off and walked home, after that we could not start it, the starter works, when trying to start it emmits white smoke (i heard its unburned fuel).
Tried spraying some fluids in to the air filter, it looks like it starts, but as soon as there is no more fluid it stops, doesn't respond to accelerator pedal at all.
Looks like it gets the fuel, baterry works fine too, what could be the problem?
   / Massey ferguson 3080 won't start #2
White smoke frequently means water. You only ask what COULD be the problem so I'll throw out the possibility of a blown head gasket. That's probably the least expensive thing it could be. In any case a bit of troubleshooting is in order.
30059 (A53424)
30059 (A53424)
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A55218)
2-Row Peanut...
Sterling 9500 (A55301)
35176 (A53424)
35176 (A53424)
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
