Front-End Loader Massey Ferguson 232 loader on a MF 240 tractor
   / Massey Ferguson 232 loader on a MF 240 tractor #1
Terryone
Ontario, Canada
MF 240
hello
I have removed the loader off my MF 232 in order to paint it. When I removed the large support that bolts to underside and side of tractor under the transmission area, I noticed that the cover plate under the tractor chassis had been removed - likely when loader was installed. Is it necessary to remove this cover plate or is there an issue if it is not in place.
appreciate your responses
Terry18
   / Massey Ferguson 232 loader on a MF 240 tractor #2
If there is no cover plate then debris and mud will get up in the bell housing and gunk up the clutch. I would fabricate a cover plate to keep the clutch clean. It is nice that the MF have an inspection plate, on some brands you would have to split the tractor to adjust the clutch.
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD72...
2011 Ford Econoline Cargo Van (A54814)
2011 Ford...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2018 Ford F-150...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A55852)
2012 Crane Carrier...
