Front-End Loader Massey Ferguson 232 loader on a MF 240 tractor
   / Massey Ferguson 232 loader on a MF 240 tractor #1
Terryone
Ontario, Canada
MF 240
hello
I have removed the loader off my MF 232 in order to paint it. When I removed the large support that bolts to underside and side of tractor under the transmission area, I noticed that the cover plate under the tractor chassis had been removed - likely when loader was installed. Is it necessary to remove this cover plate or is there an issue if it is not in place.
appreciate your responses
Terry18
   / Massey Ferguson 232 loader on a MF 240 tractor #2
If there is no cover plate then debris and mud will get up in the bell housing and gunk up the clutch. I would fabricate a cover plate to keep the clutch clean. It is nice that the MF have an inspection plate, on some brands you would have to split the tractor to adjust the clutch.
2016 Ford Explorer...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2016 Nissan Altima Sedan (A50324)
2016 Nissan Altima...
2025 CFG Industrial TK35R Mini Track Loader Skid Steer (A50322)
2025 CFG...
Hamm HD110 Asphalt Roller (A47384)
Hamm HD110 Asphalt...
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
