Massey Ferguson 1740M Hydro: LOSS OF POWER when hot!
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #21
Did you clean the suction filter when you changed the hydraulic oil and filters?
Mine is located behind the loader subframe piece that attaches to the rear axle housing. It requires removing said piece in order to get it out. Mine had some debris in it the first time I cleaned it. If yours does it may be restricting the flow some.
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #22
yeah really is looking like that. its either that or the whole hydro system is losing pressure. don't have time to dig into service manual right now (2300 and 2400 use,iirc, same parts/specs) but if I get a chance tomorrow I will post the service manual again.
fwiw a plugged suction intake filter (behind left rear tire) can cause a crapload of issues.
yeah mentioned something similar in the loss of pto power thread.
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #23
Could be (clogged suction filter) but, if it is that, it is hard to picture why that would wait 40 minutes of run time before becoming noticeable. Maybe happens as the hyd fluid gets warm enough to cause the issue ??
I concur, I'm changing both filters (and the 821XL fluid) just to be able to rule this out....
I'm barking more up this tree because (insert lightbulb above my head here!) over a year ago, I blew a hydraulic line, one that's right above the lower fuel filter and primer pump area. It went back to the dealer for repair, and, I'm sure they had to "top off" the Hyd fluid?.
Hmmm?, SO... I got thinking yesterday when JWR mentioned fluid and possible contaminants?. And, I could be just grasping at straws here, but it's something that's so puzzling that I have to look into all avenues, and, the more I got thinking.... could a mis-fill of Hyd oil been had? Most likely not since a dealer did this, but you never know if a rookie mechanic did the work?, i.e. grabbed the gear driven regular Hyd oil?. Absolutely have no idea, but I need to rule this out since my own fingers didn't do that work.
DISCLAIMER: I'm not blaming or determining anything yet. BUT!, a full Hyd oil change w filters should rule this out (or in).
My mind is still thinking;
It's weird cuz the tractor was fine for several Months, if not an entire year after that hyd line blowout. Maybe the process would take awhile also? I never saw any milkyness or murkyness in the (supposedly sight) site-glass. It's crystal clear hot or cold.
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #26
If this truly is a heat related issue I wonder if you could use a inferred heat gun to try and determine the transmission temp during your 40 min test runs? 40 min sure seems like a long time to me but maybe the transmission has enough heat mass that it takes that long for everything to warm up unlike your engine which I'd say would be warm in 10 min or so.
I'm not sure where you would measure its temp, maybe a filter housing or somewhere near a drain plug. I believe the guns are fairly inexpensive and it would at least give you a reference for the changes that you are making. Possibly before and after this fluid change that you are planning would give you some insight?
I'm sure somewhere this temperature is digitally being monitored along with many of other parameters however, we just don't have access to these.
Hi, You can remove this horizontal suction filter without removing the subframe gray bar. I have successfully done it.
I will make a thread on the entire procedure including step by step images. Give me a few days...
So today before my draining, I did the ole 40, had plenty of power during and when the power started to lag, I put her in the pole barn and immediately drained the Hyd oil. I was expecting it to be hot, but it was actually like a very warm shower, like that you'd have during the winter.
I also thought it would be milky-ish, well I was hoping anyways as then I thought I could start pointing a finger at something. Here is the pic of some of the 7.5 gls that came out...
   / Massey Ferguson 1740M Hydro: LOSS OF POWER when hot! #29
"Like a warm shower" doesn't seem very hot then. While I don't have a lot of experience with hydro oil doesn't that look pretty dark? Is what you are putting in more clear?
With your new fluid it will be interesting to see if after running for a while, 40+ min if you experience any sluggishness.
I was surprised, I was anticipating my fingers almost getting "scorched" while taking out the oil plug (during in the last few turns).
To me as well; Oil did look dark, but maybe b/c I used a white used drywall mud bucket?... used this as it was a tad lower to get under the tractor belly better. I then dumped those loads in group of 3 into my bigger oil recycling pails while noticing the more darkness than the new. At least so it appears.
Not sure if this is normal or not?
LOT: (2) Shelving Units w/Equipment Parts & Hardware (TANKS NOT INCLUDED) (A59076)
LOT: (2) Shelving...
MURRAY PUSH MOWER (A58214)
MURRAY PUSH MOWER...
2011 MERCEDES-BENZ E-Class Sedan (A56859)
2011 MERCEDES-BENZ...
400 Ton Cincinnati Press Brake (A59213)
400 Ton Cincinnati...
2019 GENIE S-45 BOOM LIFT (A52709)
2019 GENIE S-45...
2016 Audi A3 AWD Sedan (A56859)
2016 Audi A3 AWD...
