Massey Ferguson 1736 Mods
   / Massey Ferguson 1736 Mods #1
supertaster
Nova Scotia
Massey Ferguson 35 Diesel, Massey Ferguson 1736 cab Power Shuttle
I got this tractor last year and have been bitten by the mod bug. Here is a short video of the latest changes. Hopefully I can show some daylight descriptions soon
Massey Ferguson 1736 Mods - YouTube
   / Massey Ferguson 1736 Mods #2
very nice. Just got finished doing the same thing with a front lightbar and rear LED floods.
Now changing out all the oem halogen bulbs to LED; had some problems blowing fuses. Pulled one bulb out, worked fine. Time for LED's...
Let's see you mentioned Paul in your video and you are from Nova Scotia. That can only mean Paul Shorts? The best....
Thank you.
I have been wanting to change out the headlight bulbs. I put Silverstar Ultra in when I first got it home but they are still terrible.
The light bar up top is good but i have to have it on and off when traffic is passing by as i am plowing snow.
Let me know if you have success with the LED. I have had a tough time choosing bulbs online. I don't know what ones to try or what vendor to trust.
Yes i watch all of 4Shorts' videos. Lots of inspiration there.
   / Massey Ferguson 1736 Mods #6
Amazon.com: TOAUTO 2 X 8W H3 Car light Cree LED Bulb Super White Lamp For DRL Fog Light Plug-n-Play: Automotive
these are the bulbs I ordered. H3 35W halogen replacement, only uses 6W. Wanted fog, not spot, top bar like yours
has plenty of distance. These high power lights tend to blind you even in the daytime.
4000 lumens is probably not good to look at directly, kinda makes you look down or avert your eyes.
So for around the tractor I wanted a diffuse pattern from the oem lamps, which were retained, and then a combo of spots and work lamps
using high power LED.
did a lot of reading and peering at little pictures on Amazon...hopefully this will work. Mount and plug identical. Should be plenty of room inside
light to accommodate larger bulb size of LED since these lights have six to ten LEDs on them they are not super compact.
15 bucks a piece.
these replace the added lighting package lamps, not the standard tractor headlamps up front. They are next.
15 bucks a piece.
Cool. I will check it out. Thanks for the info.
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2023 Sundowner Rancher Express 24FT Livestock Trailer - All-Aluminum Stock Hauler (A55302)
2023 Sundowner...
2014 BRENNER CRUDE TRAILER (A58214)
2014 BRENNER CRUDE...
2016 Chevrolet Cruze Limited Sedan (A56859)
2016 Chevrolet...
Carolina 30-Ton Capacity Shop Press w/Pittsburg 20-Ton Jack, Model CP100, S/N 04020 (A59076)
Carolina 30-Ton...
2018 Chevrolet Tahoe SUV (A55973)
2018 Chevrolet...
