massey ferguson 165
   / massey ferguson 165 #1
robbie 6021
massey ferguson 165
hi i have a massey ferguson 165 diesel AD4.203perkins engine is it possible to remove the oil pan with out removing the front of the tractor
   / massey ferguson 165 #2
Yep
is there a video of someone doing it
   / massey ferguson 165 #4
Check YouTube and Yesterday's Tractors website for those who have documented the steps
   / massey ferguson 165 #5
Support from transmission housing
Have to take weight off front end pull front support bolts. Loosen nut on stud. bottom of front cover will come with pan
So you need to take those bolts out plus two 3/8 fine nuts in front corners
Bolts that go thru pan to bell housing plus one more by pan so it slides out easier
Then pan bolts and pry off be careful and make sure you get all the front cover bolts out I think there were four if you clean it really good are easy to see
A picture is always worth a thousand words
2006 Deere 410G (A50120)
2006 Deere 410G...
2018 Ford Transit 250 Cargo Van (A51692)
2018 Ford Transit...
2014 Deere 304K (A50120)
2014 Deere 304K...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2014 Ford Flex SUV (A50324)
2014 Ford Flex SUV...
