Canopy Massey Ferguson 1560 w/ 1530 Front Loader
   / Massey Ferguson 1560 w/ 1530 Front Loader
@Blunderbore, essentially it's like this one, only bigger.
https://www.youtube.com/watch?v=sogd6JcMBy0
The width is equivalent to the width of the Quick Attach plate. In comparison to the video it is also more flat, so I can dig up trees with a bigger root ball radius. I took me 2 or 3 trees to learn to dig out bigger root balls, so they survive. I also learned to keep the north-south orientation of how the tree grew...No, I know the leave end of the tree has to stand up and the roots go into the ground,hahaha. I mean, to keep the branches that were growing to the North before, pointed to the same direction.
For lifting the bigger trees I use the forks and a tow strap wrapped around the trunk and then lifting and moving. Works pretty well. When planting I avoid stakes, seems to make them more sturdy in the ground.
I'll take some pictures next time I'm at it.
Soooooo, it looks like I still have a cold start issue with the 1560. It works great all summer, but once it gets cold (around freezing and under) I have issue with the starting.
I now realized something: At those cold temperatures and if the tractor has been sitting for a week or more, when starting the engine the PTO starts to turn. The PTO switch (electronic) is turned off and I don't see a light in the dash that would suggest the PTO is engaged. Yet the shaft is turning for a few seconds at typical start up speeds.
When I realized this, I had the bushhog mounted on the back and the blades made a rumble and when I turned around I saw the bushhog running. I immediately hit the PTO switch, but it took a few more seconds for the PTO to stop. Well stopping as in loosing speed.
I am 100% certain that the switch was off (the tractor does not start with the PTO engaged) yet the PTO ran when starting.
I did do some research and read something that cold hydraulic il could be between the clutch and basically cause a friction connection in the clutch. Once the oil warms up a bit, the friction is lower and the PTO stops.
Any idea if that makes sense and what I would do about it? The hydraulic oil is only 50 hours old at best and I put in a new filter as well. I had no shavings on the hydraulic oil circuit magnet either.
For now I am planning on putting a magnetic heater on the rear axle housing, but that can't be the solution and I am not sure if that will be sufficient at minus 30 celsius.
Any ideas and suggestions welcome.
I will probably post this in some other sub-forum as well to get better results.
Thank you folks !!!
Oh, one more thing, I was brush cutting this spring and ripped off the drain valve of the cooling system. Luckily I saw that pretty much immediately. And of course maybe two weeks after I had just changed the coolant. New valve set me back maybe $10 plus the new coolant and of course my time.
Royal pain in the *** and the location of that drain valve is definitely a big design flaw. Same thing happened to the first owner too...
2006 IC Corporation PB305 Bus (A56858)
2006 IC...
WINCH CABLE DRUM (A58216)
WINCH CABLE DRUM...
New Holland LB75B (A57148)
New Holland LB75B...
2017 Kubota L4701 (A57148)
2017 Kubota L4701...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
