Massey Ferguson 1533 engine surging
/ Massey Ferguson 1533 engine surging #1
Gooseneck8
Waynesville, NC
Bought new 2005 in April '06. Been perfect since w/850 hours until yesterday. Hauling mulch and on 3rd load the engine started to die. Kicked in clutch and rpms surged and then died. I've checked the fuel filter, removed, cleaned canister and replaced. I'm a fairly good gas mechanic but no experience w/diesels. Will appreciate any thoughts, ideas, etc.
Thanks,
Gooseneck
Got it! A short, quick blast of air into the fuel line from the tank to filter did the trick. Decided to not remove the tank as it is a lot of trouble. Know what to do if it happens again.
/ Massey Ferguson 1533 engine surging #3
Excellent! Would a new filter now be in order and any more gunk visible in tank?
/ Massey Ferguson 1533 engine surging #4
Siphon the junk out. There is a little spill cup around the filler on these fuel tanks and they are notorious for catching water and the water seeping through the cap. Do yourself a favor and cut that booger off. Dirt dobbers and debris always plug up the little hose and doesn't allow the cup to drain properly.
/ Massey Ferguson 1533 engine surging #5
i have a 2006 1533 that did that where they drilled the tank for fuel line they lft peices of plastic in the tank drained tank and vacumed out the tank mostly around fuel line problem solved
Morgan 26ft Box Truck Body (A59230)
Morgan 26ft Box...
MASSAGE CHAIR (A58214)
2012 FORD F-350 XL SUPER DUTY CREW CAB SERVICE TRK (A60430)
2012 FORD F-350 XL...
2023 Chevrolet 1500 Silverado Z71 Crew Cab Pick-Up Truck (A59230)
2023 Chevrolet...
KITCHEN AID SUPERBA REFRIGERATOR/FREEZER (A60432)
KITCHEN AID...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
