Massey Ferguson 135, No voltage from top of the coil! Help!!
   / Massey Ferguson 135, No voltage from top of the coil! Help!! #1
gyontz
MF135
Hi Everyone, I have a Massey Ferguson 135. We are getting voltage to both sides of the coil plus points. The coil was taken to the dealership and tested as being good. We are not getting anything out of the top of the coil. Condenser has been replaced, points checked again and gaped. Insulator was checked as well. We are stumped! Any help would be much appreciated!
   / Massey Ferguson 135, No voltage from top of the coil! Help!! #2
Not trying to be a smart ***** but not knowing your level of expertise I'll ask this question. You do realize that the only time a spark is produce is each time the voltage is removed from the coil? Thats what the points do, make and break the primary circuit. The high voltage is caused by the collapsing field in the coil windings.
Welcome BTW :)..............Mike
Thank You Mike! You are right my expertise is limited to a basic knowledge. My mechanic is the one doing the work and I relayed exactly what he told me. I am fairly sure he knows that, but I will double check.
   / Massey Ferguson 135, No voltage from top of the coil! Help!! #4
Not sure on this particular coil, does it have the screw in keeper on the high tension wire? If it does, I have repaired a couple of these that don't push the wire down far enough to make contact, check your if it is this type.
   / Massey Ferguson 135, No voltage from top of the coil! Help!! #5
Is this the Perkins gas or the Continental gas engine??? By the way, have your guy change out the wire running from the coil to the distributor....and/or a new distributor cap.....BobG in VA
Hi, thank you. No this type of coil does not have a keeper.
Hi Bob G, this is the Continental gas engine. Okay on the wire and cap, I will have him try that.
Using an ignition tester we had a weak spark coming out of the top of the coil. Very weak spark, no enough to fire the plugs, going to try and replace the points and condenser again. Out of ideas after that.
   / Massey Ferguson 135, No voltage from top of the coil! Help!! #9
Dealer tested as good, what ign tester did you use/how?
You have already replaced condenser.
Does your tractor use a ballast resistor?
1996 Monon 45X96 Dry Van Trailer (A51039)
1996 Monon 45X96...
2021 Exmark Lazer Z 60in Zero Turn Mower (A49461)
2021 Exmark Lazer...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2014 VOLVO VHD DAYCAB (A50854)
2014 VOLVO VHD...
Bus (A50323)
Bus (A50323)
2005 INTERNATIONAL 4300 CARGO TRUCK (INOPERABLE) (A50854)
2005 INTERNATIONAL...
