Massey Ferguson 135 input seal replacement
   / Massey Ferguson 135 input seal replacement #1
Steady Eddy
Mf135
I am presently replacing the clutch on my MF 135 and noticed that the input seals are leaking. I have purchased new seals and would like to replace them while I have the tractor split. My service manual says that I have to also split the transmission from the differential in order for the pto shaft to move back enough to drop from the input shaft. My question is how far do I have to move the transmission in order for the pto shaft to drop and secondly do I need to take the transmission apart. Thanks for any advice you can give me.
   / Massey Ferguson 135 input seal replacement #2
If you have an eight speed transmission this is a piece of cake. If it's a six speed, different story. I'd say the distance between the the transmission and rear housing needs to at least a foot unless you are really good with your hands. I would need to have room to stand (or kneel) between the cases. The top part of the transmission needs not come apart. Shift cover, top shaft, gears and forks all stay in place. You have the manual, it (should) describe the process. Only the PTO shaft needs to move.
Thanks for the reply. My transmission is a 6 speed non multipower. The manual only describes how to dismantle and rebuild the complete transmission. Do I need to remove the the pto bearing housing shaft inside the bell housing for the pto shaft to drop enough to remove the the input shaft. Once I have the transmission split do I need to remove the planetary assembly at the rear of the transmission.
   / Massey Ferguson 135 input seal replacement #4
The planetary? I don't think so. I think once the transmission is split away from the rear housing you will see the bearing, snap rings ETC involved, but I think the front cover comes off, the small snap ring comes off the shaft and then the shaft can be driven back through the gear and the rear bearing may slide out with the shaft. It only needs to go back far enough for the gear to drop then the top input shaft assembly will come out the front. You might want (or need) to remove the front bearing support housing in order to get the gear back onto the shaft when you put it back together.
Again thanks. Your advice has been very appreciated. I will attempt to do this in the next few days. I may have more questions once I get in there. I will let you know how I make out.
   / Massey Ferguson 135 input seal replacement #6
When you have got to the rejoin stage, engage the pto and use a spanner on the pto shaft to rotate it to slide into the clutch instead of trying to rotate the gearbox input shaft. Save blue air and pinched fingers.
good luck.
I now have the clutch bolted to the flywheel. The 6 bolts are 5/16 grade 8 bolts. The service manual calls for those bolts to be torqued at 28-32 foot lbs. While torquing one bolt broke broke before I reached 25 foot lbs. I decided to replace all 6 bolts with new grade 8 bolts. Again while torquing one of the new bolts broke at 18 foot lbs. I again replaced the broken bolt and now the bolts are all torqued at 16 foot lbs and I am afraid to go any higher. 28 foot lbs on a 5/16 bolts seems high to me and all the charts I checked seem to agree. Any comments or suggestions would surely be appreciated. Thanks again
   / Massey Ferguson 135 input seal replacement #8
I don't think I've ever used a torque wrench on pressure plate bolts so I won't speak to what they should or shouldn't be torqued to. I use a long handled 3/8 ratchet and tighten them a little at a time until it "feels" right. Have never broken one and don't remember having one come loose later.
I now have new seals installed and the input shaft assembly back together. When I took the input shaft assembly and the pto bearing housing apart the two gaskets crumbled. I think they were original. These gaskets are paper thin and are almost translucent. I do not know what type of material they are made of but it does not look like regular gasket material. I would like to make new ones if I can find out what they're made of otherwise I will have to order new ones which will set me back another week or so. Thanks
Well I got the 2 gaskets from my local Massey Ferguson dealer and finally got the tractor all back together. I decided that while I'm at it I might as well change the hydraulic filter and put new tdh oil in the transmission/differential. After adjusting the clutch free play and bleeding the fuel system I finally got the tractor running. Been using it now for a few days and tractor is running great. No more issues. Thanks to all for the advice.
Galvanized Livestock Gates - (6x Total Gates) (A55218)
Galvanized...
1996 Timpte 46ft Hopper (A55301)
1996 Timpte 46ft...
24008 (A53422)
24008 (A53422)
Year: 2015 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 66,687 Plate: Body Type: 2 (A53422)
Year: 2015 Make...
2014 Ford F-150 Ext. Cab Pickup Truck (A52377)
2014 Ford F-150...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
