Massey Ferguson 135 hydraulic issue
   / Massey Ferguson 135 hydraulic issue #1
HIGHRPM
1967 Massey Ferguson 135
Desperately need help. I am trying to help my daughter with her 135. The hydraulic fluid was contaminated so I changed it, changed the filter. The 3 point has always worked great, the front forks have always been spotty in operation. Right now I have perfect 3 point operation but zero front hydraulics.I have tried two different diverter valves, same problem. I have disconnected the pressure line to the front blb bm20 controls and have virtually zero flow . How can a 3 point work perfectly and the fronts nothing ??? Terribly confused and going around in circles!
   / Massey Ferguson 135 hydraulic issue #2
Hi, and welcome to TBN. When I had that problem with my old Mitsubishi it seemed to always happen when my three point control was in the full up position. Try pulling it a bit off of full up. If that's what's doing it there is an adjustment to keep it from happening.
   / Massey Ferguson 135 hydraulic issue #3
Hello there. I hope you have her tractor/loader working by now, if not continue.
Sounds the me like you have quick connector that's not seated right. Connectors can look and feel like they are connected and still not let fluid through. On the lines going to the loader, disconnect them and reconnect. I really believe that will take care of your problem.Have a good day to your daughter and yourself.
   / Massey Ferguson 135 hydraulic issue #4
Please update us on the final solution to the problem.
Someone else may have the same trouble.
Ezflow 500 Gravity Box W/Cart (A50774)
Ezflow 500 Gravity...
New Farm-bilt 6 Lug Running Gear (A50774)
New Farm-bilt 6...
2017 CATERPILLAR 320FL EXCAVATOR (A51242)
2017 CATERPILLAR...
2015 Ford Transit 250 Cargo Van (A50323)
2015 Ford Transit...
2016 Takeuchi TW40 Wheel Loader (RIDE AND DRIVE) (A50774)
2016 Takeuchi TW40...
City of Tampa (1709) VIN: 1FTYR10U67PA38092,**Title MUST be transferred into buyer's name INCLUDING (A51692)
City of Tampa...
