Massey Ferguson 135 how hard to ad 3 point backhoe?
   / Massey Ferguson 135 how hard to ad 3 point backhoe? #1
swizz253
YELM
massey ferguson 135
Hello I have a old mf 135, has forks on the back that go up and down with control lever thats all factory. My question is i see online a lot 3 point backhoe attachments for older tractors, so im pretty sure there is no hydraulic hook up for a backhoe i dont see anything back there how difficult of a task would that be? I also notice that it has hydraulic steering but doesnt work. with all being said anyone know anything? 20150820_181428.jpg
   / Massey Ferguson 135 how hard to ad 3 point backhoe? #2
Very difficult IMHO (I used to own a 1964 MF135 diesel). The big problem is that the 135's hydraulic pump has such puny flow rate (about 4.5 gal/min), which would make BH operation very sluggish. Also 3-pt hitch mounted BHs are pretty much toys compared to BHs that are frame mounted to the tractor's main support structure. The 135 is not the best choice for a BH or for an FEL (the 135's front axle is not strong enough to handle tough FEL work).
Good luck.
Yeah the flow rate i was worried about and i also just overall figured it be quite a task to do with a payoff that might not be worth the effort, I really appreciate your opinion and i will keep the debate going if i should try or not or just look for a cheap actual backhoe.
   / Massey Ferguson 135 how hard to ad 3 point backhoe? #4
X2 on the mf135 having a weak front axle. My dad has a 1974 mf135, with mf loader. He managed to break the front axle and cast pivot housing, which was replaced with one from a mf35, while stronger, requires machine work to get the whole mess to work.
You would need a loader to counter ballance the back hoe. I also agree with not using a 3ph vs sub frame mount backhoe.
Find a complete older TLB as it will be designed to work as a unit. They can be had cheap, my neighbor sold an early 80's ford backhoe tractor for $3500, in usable condition.
2012 KENWORTH T800 SLEEPER (A50854)
2012 KENWORTH T800...
2010 CAT 140M MOTORGRADER (A50854)
2010 CAT 140M...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
Caterpillar 60in Pallet Fork and Frame Attachment (A49461)
Caterpillar 60in...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2012 WILCO MACHINE & FAB INC. WILCO MACHINE & FAB INC. (A50854)
2012 WILCO MACHINE...
