Massey Ferguson 135 Gasser wiring question with no Amp Meter
   / Massey Ferguson 135 Gasser wiring question with no Amp Meter #1
SandstoneSmitty
Carrollton, Texas
FM 135 3 cylinder Gasser
I need assistance with wiring on my Massey Ferguson 135 Standard 3 cylinder Gasser. The FM135 is a basic model without an Amp Meter.
Where do the 2 wires go that the wiring diagram show they go to the Amp Meter when the model I have does not have an Amp Meter?
History: Last Easter my Dad hauling kids around on a hay ride when the wiring harness got hot and melted. I said I would be right out to fix it. Well, it was a couple of months before I got out there. Dad had already pulled the writing harness off. I rewired the harness and ask my Dad where does the wires go. My Father has Alzheimer痴 and replied: I do not remember.
I figure壇 everything; out except 2 wires that the wiring diagram hooked to the Amp Meter. The problem is that the MF 135 I have does not have an Amp Meter. I clamped the 2 wires together.
Where do these two wires that the diagram states that go the Amp Meter hook up together?
There has to be some point where they connect to the same terminal. I do not see anywhere.
I did figure out that the cause of the wiring overheat was the cotter pin that holds the governor linkage broke. The linkage fell onto the Starter Solenoid terminal causing a short in the wiring system.
I have replaced the Starter Solenoid and got it to turn over. I have other questions that I will post in another thread.
   / Massey Ferguson 135 Gasser wiring question with no Amp Meter #2
Instead of the wire going to the amp meter it goes to the starter solenoid to the same terminal that the + side of the battery cable goes to.
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2016 FREIGHTLINER...
Glenco Disk Chisel (A50515)
Glenco Disk Chisel...
2018 Wacker Neuson WL 38 (A51039)
2018 Wacker Neuson...
2014 KENWORTH W900 MID-ROOF SLEEPER (A50854)
2014 KENWORTH W900...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
AMG M 35A2C drop side 2 1/2 ton 6 x 6 (A50323)
AMG M 35A2C drop...
