:thumbsup:
Hello,
I appologize if these questions are dumb as I just purchased some land and an older Massey Ferguson. I wanted to see what options I had on a finish mower, 16 acres to cut. Width and make and price. I am new to all of this so I may seem ignorant, that is because I am...... Thanks in advance for any help you may give.
Sean
_________________________________________________________________
First your questions are not dumb, second the
Massey 135 is great tractor whether it is a
gas or diesel.
You have not mentioned whether it is four wheel drive
and whether it is automatic or a manual transmission.
Just because your new to all this is reason enough
to ask questions of us on the forum.
You have stated the acreage is 16 acres in total
and there are many issues time available being
the primary concern if becoming a gentleman
farmer is your goal.
1. The time you have to mow, or the time you
think you have to mow.
a. the actual time you will have to mow.
b. how nasty your 16 acres gets or has gotten.
c. your allergy level in relation to the acreage and weeds
d. what kind of turf if any being old pasture/hay ground
overgrown pasture.
e. what is your budget or percieved budget/allowable expense?
f. what is your mechanical ability/experience and or your limitations and tools?
2. whether the 135 is gas or diesel powered.
wherein the diesel has more usable available power/torque.
what type of tires does it have row crop or turf or R1 or R4?
Are the rear tires loaded with liquid ballast?, if not you should plan on having them
loaded with calcium chloride, winshield washer fluid or Rim Guard or add wheel weights.
If you do not have a front end loader on the 135 you should plan on
adding a set of suitcase weights no matter the mower type or width.
Now to the mowing part
There are many issues in deciding what type of mower to buy.
Number one is whether you have walked the ground to see whats
there as many hidden objects will suddenly appear and be impacted and
thrown by a rotary mower for many hundreds of feetand there are many
examples of this in the forum archives here and the news media with regard
to injuries and deaths related to bush hogs and rotary mowers.
First the rear P.T.O. is rated for 540 R.P.M. at the rated engine
speed for the rear mounted implement.
The rear rotary finish mower or single spindle bush hog or flailmower will be
powered by the PTO shaft attached to the tractor and then to the implements
right angle gearbox.
A rear trailing or integral three point hitch rotary finish mower will have a gearbox and V belt drive
for the external spindles. The mower will have either a left right or rear discharge for the mowed
grass or brush. these types of mowers may have wind deflectors surrounding each spindle and blade
to aid in the cutting of the material encountered.
The Massey Ferguson 135 has a capacity of 2,850 pounds of lift for the three point hitch
and can handle a five foot bush hog six or seven foot flail mower.
3. As the 135 has 45 gross horsepower you can easily handle a five foot bush hog or a 7 foot flailmower
with a finish knive flail mower rotor with power to spare.
The rule of 5 horsepower per foot is one that is hot debated around here by many of the members.
Lastly I always suggest that you contact Ken Sweet here on the forum as he
is a forum sponsor in good standing and ask him about his lines rotary mowers
and flailmowers and doing business with him helps promote the forum to every
one.
Ken also ships farm equipment nationwide from his warehouse in Kentucky as well.
I want you to succeed and not to fail.
If you overbuy in width for either a rotary or flailmower you can very easily mow in several passes with half cuts if needed if the material is very tall.
About mowing in general:
If you mow to fast you will leave rooster tails of brush to be mowed again with finish rotary mower or bush hog. The same is true of flailmowers as you will burn up a set of V belts as the mowr will simply continue to work until the material wraps around the flail mower rotor and the Power Take off will continue to rotate and the drive and driven pulley under the guard will continue to rotate until the V belt is torn in half by the drive pulley.
If you start in the center of an area that you wish to mow and mow in a spiral pattern you will save time and fuel and brakes as you will not need to stop at any time while mowing and you can overlap to catch any grass or brush that was missed.
If you would like to learn more about flailmowers the attachment forum has several hundred pages regarding them and you are welcome to PM me or many of the other members here and ask questions about them specifically and other mowers.
Welcome to the forum
Once you go flail you never go back:thumbsup::licking::drool:
