Massey Ferguson 1010 Tires
   / Massey Ferguson 1010 Tires #1
rolawson
I have a 4x4 Massey Ferguson 1010 with 21x8.00-10 front tires. They have discontinued that tire and are recommending the 20.5x8.00-10 tire. The problem with that tire is that the choices are limited. Is going with the 20x8.00-10 to big of a reduction in diameter? I do not want to hurt the front differential when in 4 wheel drive.
   / Massey Ferguson 1010 Tires #2
have you ask your dealer ? you can’t go bigger ? you would change both font tire right ? … so yes your rotation would be higher but i would assume as long as you don’t go on long drive at high speed you should be fine as far as your differential goes.
I would be changing both front tires. My rear tires are in good shape. Sadly I don't have a dealer close by. I am going to see where the closest one is and give them a call.
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
UNUSED CFG QH12R EXCAVATOR (A51247)
UNUSED CFG QH12R...
KUBOTA M7-132 (A53084)
2007 Ford Ranger Pickup Truck (A51692)
2007 Ford Ranger...
2002 HAYS SDBTH36SS KILLEBREW FERTILIZER TENDER TL (A51247)
2002 HAYS...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
