Massey Ferguson 1010 Tires
   / Massey Ferguson 1010 Tires #1
rolawson
I have a 4x4 Massey Ferguson 1010 with 21x8.00-10 front tires. They have discontinued that tire and are recommending the 20.5x8.00-10 tire. The problem with that tire is that the choices are limited. Is going with the 20x8.00-10 to big of a reduction in diameter? I do not want to hurt the front differential when in 4 wheel drive.
   / Massey Ferguson 1010 Tires #2
have you ask your dealer ? you can’t go bigger ? you would change both font tire right ? … so yes your rotation would be higher but i would assume as long as you don’t go on long drive at high speed you should be fine as far as your differential goes.
I would be changing both front tires. My rear tires are in good shape. Sadly I don't have a dealer close by. I am going to see where the closest one is and give them a call.
TANNKO  130BBL VAC TRAILER (A50854)
TANNKO 130BBL VAC...
2020 Kinze 3505 High Speed 6/11 Planter (A51039)
2020 Kinze 3505...
1998 CATERPILLAR TH103 TELESCOPIC FORKLIFT (A51242)
1998 CATERPILLAR...
2016 FORD F-250 SUPER DUTY SERVICE TRUCK (A51243)
2016 FORD F-250...
1977 Allis Chalmers 7060 Tractor (A50514)
1977 Allis...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A51222)
2015 INTERNATIONAL...
