Massey Fergus0n 203 with 220 FEL Hydraulic Tank Dipstick. Length
   / Massey Fergus0n 203 with 220 FEL Hydraulic Tank Dipstick. Length #1
mllud
Missourian
Massey Ferguson / New Holland 3010/ Ford 3550 Backhoe
. I fished the dipstick out of the hydraulic tank on a 220 FEL on a Massey Ferguson 203. I believe a 220 FEL. Tags gone off of the loader frame hydraulic tank. There is a short ball chain that goes between the filler vent cap and the dipstick.
The dipstick in the photo hangs from a short chain. I'm missing the chain and need the length of just the chain.
Thanks Mike
   / Massey Fergus0n 203 with 220 FEL Hydraulic Tank Dipstick. Length #2
How did you retrieve the dip stick?
Well I guess that style dipstick didn't hold up well. There are probably not many left. I had the little chain but cant find it now.
I remember it being about 3" or 4" long. Ill get a chain that's about 2.5" long and a little stronger. That dipstick isn't heavy but I don't think that ball link chain is very strong. Making it a little shorter than I remember will assure a good fluid level. That will make the dipstick low level mark about 4" above the oil pickup tube for the pump.
Thanks Mike
You unscrew the vent cap. The dipstick hangs on a short chain connected by a pin going through the fitting
A photo of the marks that don't really represent a lot. Both marks are about 7 to nine inches above the pump suction tube.
Its not like an engine oil dipstick tube. Not as critical.
I just went up and did some measurements and have decided to hang it from a three inch chain and a swivel. That leaves about 12" of air space above the full mark. About 8" of oil above the suction tube to the low oil level mark.
If I had thought more about it earlier this is one of those situations where { close} is good enough.
An inch or two either way wont hurt anything. Keeping it above the low mark will work
Thanks Mike
   / Massey Fergus0n 203 with 220 FEL Hydraulic Tank Dipstick. Length #6
Right, I know that. Had your dipstick broken away from the chain and dropped to the bottom of the side frame reservoir? If so, how did you "fish" out the dipstick from the bottom of the frame?
Workbull 203
I misread your question. I used a telescopic magnet on a string. The loader frame is off of the tractor. I'm cleaning it up to paint.
Found cracks to weld.
   / Massey Fergus0n 203 with 220 FEL Hydraulic Tank Dipstick. Length #8
Thank you mllud.
Frontier GM1084 (A50123)
Frontier GM1084...
2025 SDLANCH SDLE20 UNUSED Mini Excavator (A53117)
2025 SDLANCH...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
JOHN DEERE Q 850 M LOT NUMBER 210 (A53084)
JOHN DEERE Q 850 M...
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
2022 John Deere RD35F Draper Head (A53342)
2022 John Deere...
