Massey 65-Engine ID help please.
/ Massey 65-Engine ID help please. #1
Mean Jean
Hazelridge, MB
Kubota L1801 and Massey 65
Replacing the valve cover gasket on a Massey 65 and need to confirm the proper valve cover gasket. I see this tractor came with 2 different Diesel engines:
Perkins 4A-203.
It's a 203.5 cubic inch L head engine.
Or
Perkins A4.192
It's a 192 cubic inch engine.
Serial number of tractor is 681068.
Stamper number of motor is RMO 18826-1.
Valve cover has 3 nuts to hold the cover down instead of the usual 6-10 which are along the perimeter. Not sure why I can't post a picture..,
Also
Should I adjust the valve clearance while I'm in there?
Thanks all
Jay D
/ Massey 65-Engine ID help please. #2
G'day I would say if you have three holdown nuts then it is a 192 can't remember a 203 with that setup
Jon
They sump in oil pan is vertical and does not have a "wedge" which leads me to believe it's a 203.
Also, the oil filter is vertical which also indicates it's a 203.
The injectors are vertical which is a trait found in the 192.
Yikes!
John Deere 772-A Grader (A62679)
John Deere 772-A...
2015 Chevrolet Silverado Pickup Truck (A62613)
2015 Chevrolet...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
New/Unused Wolverine Hydraulic Hay Bale Squeeze (A65583)
New/Unused...
2005 JOHN DEERE 310G BACKHOE (A65053)
2005 JOHN DEERE...
